Old 07-04-2011, 11:57 PM   #1 (permalink)
127.0.0.1
mitraark's Avatar
Default Too much HDD Usage?
I share many files over DC++ [ somewhat similar to uTorrent ] in my college network. I upload constantly at 11 MB/s , and my PC runs for 15-20 Hours daily , so total upload is around 30x15= 450 GB atleast per day , i.e. , 450 GB of data is read from my HDDs per day.
I have 2 TB WD Green HDD and a 1 TB Seagate Freeagent. Is so much of read from a HDD going to make it corrupt ??? How much read [ not write ] can a HDD take ??? Is the read cycles of HDD limited ???
If any additional info is required i will give.
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 08-04-2011, 01:30 AM   #2 (permalink)
Stuck in Time...
Vyom's Avatar
Default Re: Too much HDD Usage?
I am very much sure just reading the drives, wont make it corrupt !
Theoretically it should be able to do that for infinite times. But wait for an expert to answer, or someone with some practical info.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 08-04-2011, 03:29 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
that's darn high amount of load on HDD. see if you can keep the HDD temps low all the while by installing extra fans pushing cool air onto HDDs. increases HDD life.
desiibond is offline   Reply With Quote
Old 10-04-2011, 10:00 PM   #4 (permalink)
Living to Play
gameranand's Avatar
Normal Magnetic hard drives don't have read or write cycles. Pendrives and SSDs have this problem so as long as your temp of hard disk is low its not a problem at all.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 14-04-2011, 11:53 AM   #5 (permalink)
127.0.0.1
mitraark's Avatar
Thanks for that info , does bring some much needed relief. Will start using the Seagate Freeagent vertically , it will help dissipate more heat than when it is kept flat.
My Speedtest :D
Old 14-04-2011, 08:55 PM   #6 (permalink)
Stuck in Time...
Vyom's Avatar
^^ Hmm.. keeping it vertically!
I hope I can do the same thing, with my Internal hard drive!
Old 14-04-2011, 09:07 PM   #7 (permalink)
127.0.0.1
mitraark's Avatar
Yea , before i kept like this
Now i keep it like this
My Speedtest :D
Old 14-04-2011, 10:08 PM   #8 (permalink)
Stuck in Time...
Vyom's Avatar
^^ Ahem, Ahem! I am pretty sure, people here, very well know, what "keeping vertically" means
Btw, the stand reminds me of this laptop stand:
Old 15-04-2011, 10:53 AM   #9 (permalink)
Uhu, Not Gonna Happen!
gagan007's Avatar
HDD have mechanical parts on which the spindle moves/rotates (although read/write per se does not require the head to touch the platter).
As your HDD performs too much operations as compared to normal usage, it is bound to go kaput sooner.
My personal blog - http://gagan.scholarguru.com
gagan007 is offline   Reply With Quote
Old 15-04-2011, 11:08 PM   #10 (permalink)
Originally Posted by gagan007 View Post
although read/write per se does not require the head to touch the platter.
if it does (ever), you'll know it from the other room.
Old 15-04-2011, 11:15 PM   #11 (permalink)
BE FREE
only problem would be short life............ and especially that free agent one keep it horizontal ............ as from my experience I had to replace it 3 times in 3 months, before I started keeping it horizontal, now its running for a year or so,
and as Sam said you would start hearing ricking noise quite clearly and your data is gone..........
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline   Reply With Quote
Old 16-04-2011, 10:14 PM   #12 (permalink)
127.0.0.1
mitraark's Avatar
Nope , no noise or anything , yet , thankfully.
I know anything that moves is bound to deplete , just wanted to know how much can it take.
Also , are you sure keeping it vertically would cause problems ? Keeping it horizontally means it would be too close to suface in the bottom , hence more heat, just started using it vertically since yesterday.
My Speedtest :D
- by c4u
