Old 06-04-2011, 07:51 PM   #1 (permalink)
User Name's Avatar
Question Need Hardware Temp monitor s/w
Hi
I need a hardware temp monitor s/w.
s/w that monitors all temps. CPU, HDD. GPU etc. for win7
should be available on desktop.
Any free software?
User Name is offline   Reply With Quote
Old 06-04-2011, 08:34 PM   #2 (permalink)
damnbadman666
damngoodman999's Avatar
Default Re: Need Hardware Temp monitor s/w
CPU-Z hardware monitor
Download >>> CPUID - System & hardware benchmark, monitoring, reporting
damngoodman999 is offline   Reply With Quote
Old 06-04-2011, 09:22 PM   #3 (permalink)
Super Moderator
asingh's Avatar
Apart from that CoreTEMP and RealTEMP (Intel only) also are good.
asingh is online now   Reply With Quote
Old 07-04-2011, 10:29 AM   #4 (permalink)
Tensor
Speedfan
Originally Posted by Blizzard
...and the heavens shall tremble...
Diablofans
Force Strategy Gaming
YouTube
Xfire
Gaurav Bhattacharjee is offline   Reply With Quote
Old 07-04-2011, 10:41 AM   #5 (permalink)
Super Moderator
asingh's Avatar
Originally Posted by Gaurav Bhattacharjee View Post
Speedfan
Nopes. Not reliable anymore.
Old 07-04-2011, 05:43 PM   #6 (permalink)
MegaMind's Avatar
HW Monitor!
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 07-04-2011, 06:32 PM   #7 (permalink)
Fullbring
Zangetsu's Avatar
CPU: CPU-Z
GPU: GPU-Z
HDD: HDD Info
Old 08-04-2011, 05:13 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
HWmonitor Pro / HWmonitor ( free )
Everest ( commercial )
Open Hardware Monitor ( free )
- above three can show all of your required system temp in one interface
ToPsPeEeD = FaSt BuT StEaDy
Old 14-04-2011, 09:11 PM   #9 (permalink)
127.0.0.1
mitraark's Avatar
AIDA64 , but it requires a License after 30 Days
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 22-04-2011, 05:25 PM   #10 (permalink)
R2K
In the Zone
R2K's Avatar
Does HWmonitor work with AMD Sempron proccy(Single core)
Acer Aspire 4930G laptop- Core 2 Duo T5800 3GB ram, 320GB+LG XG1(2TB),nVIDIA 9300GS 256MB,FingerPrint Scanner,HDMI, 802.11a/b/g/Draft N Wifi
Sony Ericsson Xperia Arc S (Gloss Black)
R2K is online now   Reply With Quote
Old 22-04-2011, 08:25 PM   #11 (permalink)
Never give up!!
jerrin_ss5's Avatar
how come speedfan has become unreliable ?
as i am getting same readings in hardware monitor pro
apart from system fan readings all other readings are proper i guess !!!
AMD Phenom-II X4-810:| || Zotac 8200 A-E :sad:||OCZ PC2 6400 -2GB + 1GB (platinum + gold edition ):-) || Segate 250GB & WD green 500GB :||| ZOTAC GTX 460 1Gb DDR5 :grin:|| Cooler Master GX550W Bronze:||| AOC 2236VW:grin:.
jerrin_ss5 is offline   Reply With Quote
Old 23-04-2011, 05:02 AM   #12 (permalink)
Fast 'N' Furious
topgear's Avatar
I guess not
Old 23-04-2011, 09:16 AM   #13 (permalink)
R2K
In the Zone
R2K's Avatar
what other software do u suggest?
Old 23-04-2011, 10:04 AM   #14 (permalink)
Wise Old Ghoul
Piyush's Avatar
all cpu monitor--->windows 7 gadget
but you should have core temp running in background to make it work i guess
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline   Reply With Quote
Old 24-04-2011, 07:09 AM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
^^core temp / Real Temp / HWMonitor don't support old cpus - they supports cpus starting from dual cores ( though intel D8xx and 9xx series not included )
@ R2K - For monitoring such old cpu temps use Everest Ultimate Edition / AIDA64 Ext. Edition - these are paid apps but if you know the method then you'll be able to monitor the temps with them without any kind of restriction always
- by c4u
