Old 04-04-2011, 10:49 PM   #1 (permalink)
Default Pen drive Trouble
I have a pen drive which some how got corrupted. It happened as I took it to a cafe attached it to the PC then (escan was installed there thus had to enter password before using) inserted password it came up with the files and further it was gone with showing only the drive which I was unable to access or format as it said please insert a disk in i:\.
I tried to format at my home via following methods:
1.in win7
2.Ubuntu
3. via booting through win7 DVD xp cd and ubuntu cd.
4. tried software provided in hiren's boot cd 13.1 for them.
5. tried low level formatting
I there any hope to restore the Pendrive.
Abhinav
abhinav_sinha is offline   Reply With Quote
Old 05-04-2011, 09:48 AM   #2 (permalink)
Default Re: Pen drive Trouble
1. Log in as Administrator account in windows or any other account with administrative privileges
2. Insert your removable disk into the USB port.
3. Click Start, now right click on my computer and select manage
4. Now, click Disk Management
5. Right click on your removable drive partition and select Change Drive Letter and Paths under Disk Management ( you can find your drive easily through size )
6. Change the drive letter some other drive letter like X: or Z: which is not reserved by some other drive on windows.
P.S- I think pendrive may be dead. What is brand of your pendrive?
thetechfreak is online now   Reply With Quote
Old 05-04-2011, 11:58 AM   #3 (permalink)
Already tried just forgot to mention
Quite possible but you see the way it became useless I am just trying to figure if there is a way to revive it.
kingston.
Abhinav
Old 05-04-2011, 09:44 PM   #4 (permalink)
Cool Buddy's Avatar
If it's under warranty, get it replaced, they replace it very easily at kingston
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 14-04-2011, 09:17 PM   #5 (permalink)
127.0.0.1
mitraark's Avatar
Try formatting it in Linux if possible
Intel i5 760 || Gigabyte H55 || Corsair 4GB 1333MHz Value || XFX HD5670 1GB
WD 2TB Green + Seagate 5900RPM 2 TB + Seagate Freeagent 1 TB x2
Corsair CX400 || Zebronics Bijli || Samsung P2350 23.5" || Altec Lansing VS2621
My Speedtest :D
mitraark is offline   Reply With Quote
Old 14-04-2011, 10:40 PM   #6 (permalink)
Stuck in Time...
Vyom's Avatar
@OP: What kind of "inserted password" are you talking about in the first post? You said,
"inserted password it came up with the files and further it was gone with showing only the drive"
So you mean, at first files were shown, and then it suddenly vanished?
Can you clarify the point. With the error message you are facing, drive is most probably gone kaput. Replacing it is the BEST option, if you have the original bill.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 16-04-2011, 03:40 PM   #7 (permalink)
Where's my M4A1
Try to format it with BIOS works sometimes
Keep the faith, not here to win trophies, not here to win the league, only here to show people how we play.... ARSENAL!!!!!!!!!!!!!!!
1993gregory is offline   Reply With Quote
Old 18-04-2011, 09:12 AM   #8 (permalink)
escan blocks pen drives use when it is inserted in the pc unless the user authorizes by inserting the password set by the admin for its use.
yes
Posting the screen shot while I try to format or access the drive.
Kaput! I think so.Can't avail as last year the drive case was busted although the drive was working quite nicely. Otherwise wouldn't have posted the thread in the first place.
Sorry to be rude but did you read the thread properly as I have mentioned what I tried before posting.
Any way bought new one.
Abhinav
- by c4u
