Old 01-04-2011, 08:30 PM   #1 (permalink)
ghantaukay's Avatar
Default Upgrading Advice required
I am upgrading my pc.New mobo and proci.Before I start assembling my new pc, I want to know what precautions I must take. Eg. I want to change my mobo and proci. But I want to keep my old files as they are. I have installed my Win 7 system files in C: Drive. All else in my other partitions. My C Drive will get formatted I suppose. SO what should I do first?
ghantaukay is offline   Reply With Quote
Old 01-04-2011, 11:03 PM   #2 (permalink)
Default Re: Upgrading Advice required
Copy all songs, pics and videos to external Hdd or Pen drive
Copy setup files of software you are using.
You may format c drive only if you want. But you have to ensure sufficient space for installation.
Any other important files needs backing up as well.
thetechfreak is online now   Reply With Quote
Old 01-04-2011, 11:25 PM   #3 (permalink)
cute.bandar's Avatar
When I upgraded, I didn't have to format. windows detected the new mobo and installed drivers for the it with no problems
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
cute.bandar is online now   Reply With Quote
- by c4u
