Old 30-03-2011, 04:05 PM   #1 (permalink)
Your Ad here
nisargshah95's Avatar
Question Play movies in DVD player. How?
Hi, I've Philips DVP 3120 DVD player. I want to watch the movies which come with Digit. So I'm wondering how can I make them play. The philips support site does not specify the extensions supported by the DVD player.
Will the AVI files play?
How do I convert MP4 files to play in DVD player?
“The Web is like a dominatrix. Everywhere I turn, I see little buttons ordering me to Submit.”
ASUS P5KPL AM/PS | P4 @ 3.07GHz | Ubuntu 11.04 / Win Server 2k8 / XP SP3 | 1GB DDR2 | Samsung HD080HJ 80GB
nisargshah95 is offline   Reply With Quote
Old 30-03-2011, 06:36 PM   #2 (permalink)
Fullbring
Zangetsu's Avatar
Default Re: Play movies in DVD player. How?
I think philips dvp3120 play avi,mpeg files...check if its a divX Player if yes the no need to convert mp4 files....
user SUPER to convert to any video format.
use the above app to convert files to .vob format.
Old 30-03-2011, 07:28 PM   #3 (permalink)
Your Ad here
And how do I check whether it's DivX compatible?
PS - AVI doesn't work. I converter to AVI suing K-Lite and then burned it as a data CD (because AVI was not an option in Video CD). The player refused to play it. ((
I still got to check out SUPER. Let's see what happens!
Old 30-03-2011, 08:39 PM   #4 (permalink)
A normal DVD player can play AVI files....try converting using this- link--
Total Video Converter - Free software downloads and software reviews - CNET Download.com
Old 31-03-2011, 11:28 AM   #5 (permalink)
Fullbring
Zangetsu's Avatar
@nisargshah95: u have this model
DVP3120/05 Philips DVD player DVP3120 - Philips Support
sorry but its not a DivX player & supports MPEG1 & MPEG2 compression in video.
generally the DivX logo is printed on the DVD player dat supports.
also it doesnt have USB.
so the only files it supports is .mpg & .vob
Old 31-03-2011, 05:22 PM   #6 (permalink)
Your Ad here
Question Re: Play movies in DVD player. How?
I'm converting a 734MB file using SUPER from AVI to MPG. But the coversion is still going on and the file size has reached above 1.3 GB!. Do MPG files take more space than AVI?
Old 31-03-2011, 06:23 PM   #7 (permalink)
Well, they take space but such a HUGE difference??
Are you sure the resolution and other quality settings are in default or they have been upped?
Old 31-03-2011, 06:27 PM   #8 (permalink)
Your Ad here
They're default. At last it ended at 1.3GB. Whoa! And I thought my PC would blast soon!
Old 31-03-2011, 06:30 PM   #9 (permalink)
The conversion must have taken several hours.
Get the player checked at a dealer.
First, try using a smal converted file
Old 31-03-2011, 06:39 PM   #10 (permalink)
Your Ad here
Yeah! took more than 2 hours. That's why I was worried. I guess MPG will work because the manual says it supports VCDs.
Old 31-03-2011, 08:17 PM   #11 (permalink)
Also try using a lens cleaner. That might do the trick.
Get it serviced.
Old 31-03-2011, 09:43 PM   #12 (permalink)
Your Ad here
Yeah. But I don't think dad will allow.
Old 02-04-2011, 09:52 AM   #13 (permalink)
Your Ad here
Can you also tell me whether this DVD player (Philips DVP 3120) will play PAL or NTSC. If both, which will be better?
Old 02-04-2011, 10:36 AM   #14 (permalink)
Get all info here-
Old 02-04-2011, 11:19 AM   #15 (permalink)
Your Ad here
Thumbs up Re: Play movies in DVD player. How?
There's no particular information given there. But I searched about it and got it. Thanks!
- by kool
- by ax3
