Old 29-03-2011, 07:32 PM   #1 (permalink)
saswat23's Avatar
Unhappy PSU Selection. Help!!! Its URGENT..
I am looking for a good PSU for around 2.5k. The dealer here has only FSP SAGAII 500W and CX-430. Both are for 2.6k.
I know CX-400 would have been a better choice here but the dealer says he can't get it. So, which one should i opt for. Plz reply ASAP coz i have to give him the final selection 2moro.
Plz help...
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 29-03-2011, 08:07 PM   #2 (permalink)
Default Re: PSU Selection. Help!!! Its URGENT..
^^ not open to buying online? well price inc shipping will be around 2.3k for the FSP unit. well, get the FSP.
Old 29-03-2011, 08:16 PM   #3 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
FSP Saga II 500W anyday
Anyways dont expect that to support the rig in ur signature
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline   Reply With Quote
Old 29-03-2011, 08:42 PM   #4 (permalink)
saswat23's Avatar
ajai5777,
dont worry. My rig is gonna be updated with SB within a week. I hope then u can judge whether FSP can handle it.
Sam,
if it would have been a COD system i could have opted. But my father wont allow for online transaction. So, its better to get FSP for 0.3k rather going for generic ones available here.
BTW,
Zeb. 600W Plat. -- 2.6k
IBall 600W Plat -- 2.9k
CM 650W -- 4k
Also i cant afford these.
Still any other views....
Old 29-03-2011, 08:48 PM   #5 (permalink)
MegaMind's Avatar
If not CX400 then FSP Saga ii 500
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 29-03-2011, 09:46 PM   #6 (permalink)
saswat23's Avatar
And what about cabby then??
No GAMMA. Only one shop has CM, and i think they will definitrly charge higher.
So, should i go with Zeb. Any good models..
Old 29-03-2011, 10:00 PM   #7 (permalink)
TechFanatic
sparx's Avatar
Get the suggested corsair or FSP PSUs anyhow, never go for those "faltu" zebronics or iball or what ever crap the shopkeeper supplies. Yeh computer ki life ka swaal hai!
sparx is offline   Reply With Quote
Old 29-03-2011, 11:21 PM   #8 (permalink)
saswat23's Avatar
I know it dude. But came to know Corsair cx430 is not good as cx400. So, i will better go with FSP SAGA at 2.6k.
Also suggest some cabs. Bijli here costs 2.3k. So, you can think what would the cost of CM Elite 430 would be here.
So, i am thinking to get a good looking generic cabby for 0.8k instead of getiing Bijli for 2.3k. If better models would be abvailable later, i can go for a good one.
Old 29-03-2011, 11:29 PM   #9 (permalink)
MegaMind's Avatar
CM 310, 430?
CM 335 w/side panel?
Old 29-03-2011, 11:37 PM   #10 (permalink)
TechFanatic
sparx's Avatar
primeabgb is currently giving free shiping for limited period, try getting a proper cabby online from there. Good time to exploit the offer. Otherwise shipping cost for cabby goes over Rs.500
Old 30-03-2011, 12:22 AM   #11 (permalink)
MegaMind's Avatar
OP's prob is not shipping cost, no online transaction...
Old 30-03-2011, 12:59 AM   #12 (permalink)
ajai5777,
Sam,
BTW,
CM 650W -- 4k
diwali cracks are cheaper than these & gives out louder bang.
STATUTORY WARNING: playing with electronic cracks & that also inside your PC is bad for your PC's health.
if PSU = FSP Saga II, avoid all cabby with bottom mounted PSU.
Old 30-03-2011, 02:46 AM   #13 (permalink)
well you can go for Corsair CX430 too. It isn't bad, the thing is CX400 was too good. Many people thought CX430 was crap, but JonnyGuru rated it quite well saying it gives you what it is labelled for. Sam has mentioned about short cables in FSP Saga II PSUs.
Is Seasonic available in your area?
Old 30-03-2011, 08:40 AM   #14 (permalink)
saswat23's Avatar
No Seasonic, No Tagan, No Antec. Not a single branded PSU available here. Only CM, Zeb., IBall and other generic ones. One dealer has agreed to get corsair and fsp for me. But the options for me are cx430 and sagaii 500w. So, which one to go for. Both will cost 2.6k.
Also whats the warranty of sagaii 500w.
I think i wont be going for bottom mount PSUs. So, which one will be better PSU.
ICO,
as u said cx430 will give 430w and sagaii will give 500w. So, will sagaii 500w not be a good choice???
Plz be fast. I have to order the psu 2day.
Old 30-03-2011, 01:37 PM   #15 (permalink)
MegaMind's Avatar
then get fsp 500, but it can support upto 6850 only...
Is that ok?
Old 30-03-2011, 02:25 PM   #16 (permalink)
saswat23's Avatar
Yes, i have ordered fsp 500w
Thank you all.
Mods can close the thread now..
- by kool
- by ax3
