27-03-2011, 07:11 AM
#1 (permalink )
Diff. Betwn WD Caviar Black, WD Scorpio Black and WD VelociRaptor.
Plz explain me the difference between WD VelociRaptor, WD Caviar Black and WD Scorpio Black. All these are SATA-3 compatible i.e have 6Gbps connectivity. Then whats the real difference. Why are the VelociRaptors priced higher than the Blacks??
Plz explain.
I couldnt understand even after googling.
Spoiler :
i5-2400 |
P8H67M-EVO |
DRW 24B3ST |
WDC Blue 500GB |
VENGEANCE 4GB DDR3 |
FSP SAGA-II 500W |
Zebronics Aviator |
DELL IN2020M |
MS Wired 500 Combo |
Creative A-35 | iBall Rocky Headset
27-03-2011, 09:23 AM
#2 (permalink )
change is constant!!
Re: Diff. Betwn WD Caviar Black, WD Scorpio Black and WD VelociRaptor.
WD VelociRaptor's are fast compare to wd black editions, because it got fast access time,and also these drives are quiet(makes less noise).
WD Black editions are power hungry drives!. also they are vibrant (not quiet).and used in desktop
WD scorpio black uses less power than normal black editions, and optimizes performance,that's why these are used in notebooks.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
27-03-2011, 09:43 AM
#3 (permalink )
Means Scorpio is used in mobile platforms. Fine
But just Bcoz VRs are quiet they are priced high. I think there might be something else too.
Spoiler :
i5-2400 |
P8H67M-EVO |
DRW 24B3ST |
WDC Blue 500GB |
FSP SAGA-II 500W |
Zebronics Aviator |
DELL IN2020M |
27-03-2011, 10:51 AM
#4 (permalink )
Originally Posted by
saswat23
WD VelociRaptor's got 10,000 RPM speed (faster access time). where as other's have 7200 rpm
currently WD VelociRaptor drives are availiable in 600GB , and got 5 years warranty..
27-03-2011, 11:34 AM
#5 (permalink )
May be the access time is fast in VRs, but is there any difference in transfer rates as compared to WDC Black SATA3
Spoiler :
i5-2400 |
P8H67M-EVO |
DRW 24B3ST |
WDC Blue 500GB |
FSP SAGA-II 500W |
Zebronics Aviator |
DELL IN2020M |
27-03-2011, 07:34 PM
#6 (permalink )
saswat23
Although there is no much difference in data transfer, but there will be a noticeable difference when u run programs or games especially.
An ex:
If you transfer a single 4.5GB file. you don't feel any difference on both drives. but on the same system config if you transfer a 4.5GB folder which has around 10,000 (or more) files . then you can see the VelociRaptor copies faster compared to other drives, thats becoz it has 10,000 rpm, this decreases seek time and increases the file access faster and it can get as fast as to the buffer,and then to the destination.
Note: these high RPM drives are usually used by heavy Gamers who don't like wasting a second!.
IMO its not safe to keep imp data on this drives
I hope u got it this time...
28-03-2011, 01:47 PM
#7 (permalink )
Yeah, indeed very well explained.
But whats the diff. Between SSD and VRs now!!!
Spoiler :
i5-2400 |
P8H67M-EVO |
DRW 24B3ST |
WDC Blue 500GB |
FSP SAGA-II 500W |
Zebronics Aviator |
DELL IN2020M |
28-03-2011, 01:52 PM
#8 (permalink )
saswat23
SSD is not a hard disk. WD VelociRaptor is a hard disk.
Solid-state drive - Wikipedia, the free encyclopedia
28-03-2011, 04:49 PM
#9 (permalink )
O thanks. Cleared
Spoiler :
i5-2400 |
P8H67M-EVO |
DRW 24B3ST |
WDC Blue 500GB |
FSP SAGA-II 500W |
Zebronics Aviator |
DELL IN2020M |
