Old 26-03-2011, 01:05 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
rahul_c's Avatar
Default BSOD again!
I was getting multiple blue screens on my Dell Vostro 1510 laptop, to make sure I didnt have any software issues I formatted the entire HDD. But today I got it again! Is there any way to get rid of them?
I have attached the log files(RAR archive renamed for uploading) it consists of two files - 032611-16801-01.dmp and WER-39312-0.sysdata.xml
rahul_c is online now   Reply With Quote
Old 26-03-2011, 08:08 PM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Lightbulb Re: BSOD again!
Your BSOD dump clearly shows that you are using a Huawei Mobile device, most probably one of their 3G Modems and using Mobile Connect software to connect to internet. The cause of BSOD was Ewusbnet.sys which is part of the Huawei driver package for their modems and it's a driver for USB NDIS Miniport.
If problem persists, upgrading to a newer version of Mobile Connect or reinstalling the current version might resolve the issue.
debsuvra is offline   Reply With Quote
Old 26-03-2011, 09:44 PM   #3 (permalink)
rahul_c's Avatar
Default Re: BSOD again!
I already have upgraded the firmwire and mobile connect software from DC-files.com, there are no individual driver updates so I reinstalled them but that is not going to solve it cause I had already formatted my HDD earlier.
I guess I will have to live with it until HUAWEI fix it.
I noticed a thing while re-installing mobile connect software it shows '3G USB fake (COM3)' it had never happened earlier, it looks spooky.
Thanks at least I now know my data card is the root cause of the blue screen. @debsuvra which line specify the cause of problem, just want to know for future reference?
Old 27-03-2011, 01:36 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Just ran your dump on Win Debug. Shows it is the USB device which Debsuvra told you.
asingh is online now   Reply With Quote
Old 27-03-2011, 09:28 AM   #5 (permalink)
rahul_c's Avatar
Win Debug is not available individually, I googled and found 'Microsoft Windows SDK for Windows 7 and .NET Framework 4 ' this is a heavy download. Cant I run dmp file on any other simple software?
Old 27-03-2011, 10:29 AM   #6 (permalink)
Super Moderator
asingh's Avatar
Blue Screen Viewer.
Old 27-03-2011, 02:09 PM   #7 (permalink)
rahul_c's Avatar
Thanks.
Old 02-04-2011, 09:02 AM   #8 (permalink)
rahul_c's Avatar
I downloaded a hot patch for HUAWEI E1550 from here - Download HUAWEI E1550 DataCard Windows/MacOS Driver, Software | Wireless Driver & Software
It as of now(2 days) seems to have fixed the problem, will post if get BS again.
Old 03-04-2011, 11:40 AM   #9 (permalink)
rahul_c's Avatar
Got it again!!
Old 03-04-2011, 12:23 PM   #10 (permalink)
Super Moderator
asingh's Avatar
Post the last three dump files.
Old 03-04-2011, 06:51 PM   #11 (permalink)
rahul_c's Avatar
OK
Old 03-04-2011, 08:17 PM   #12 (permalink)
Super Moderator
asingh's Avatar
Is that a folder..? Or Zipped..?
Old 03-04-2011, 08:20 PM   #13 (permalink)
rahul_c's Avatar
its a rar archive
Old 03-04-2011, 08:29 PM   #14 (permalink)
I am having a BSOD problem. Please help me in getting the dump files. Where to find the dump files?
bhaskar is offline   Reply With Quote
Old 03-04-2011, 11:22 PM   #15 (permalink)
Super Moderator
asingh's Avatar
c:memory dumps
Old 05-04-2011, 06:55 PM   #16 (permalink)
rahul_c's Avatar
^Its a RAR achieve renamed as PDF
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/138503-bsod-again.html
Скачать HUAWEI E1550 DataCard Windows / MacOS драйверов, программного обеспечения | Беспроводная драйверов и программного обеспечения This thread Refback 25-07-2011 12:46 PM
- by kool
- by ax3
