I have this strange problem my screen goes blank randomly every few seconds. Earlier it used to be only while playing some graphic intensive games but now it happens when i am on the desktop also .. recently i noticed that it kept going blank during boot-up and shut down also.
The rest of the hardware seems to be running fine and programs are running while the screen is blank only the signal to the monitor keeps getting interrupted, if it stays blank for too long than the monitor shows a "no signal" message.
I have also noticed that the more graphic intensive the task the worse the problem becomes, for example I just installed dead space 1 and the moment the game started loading the screen went blank and stayed that way, only after ctrl-alt-del and the task mgr starting up (game running in background) did the screen come back on.
My Config :
Proc- Intel Dual core 3.0Ghz
MoBo - Mrecury PI945GZD
ram - 2.5GB DDR 2
Graphic - MSI HD radon 5750
PSU - iball 400W
Monitor - ViewSonic VA1703wb
Please realy need help with this problem ... its extremely frustrating specially while playing games like CS
