Hi I used speedfan to check my pc temp is this temp normal at idle specially for the GPU only utorrent is running in background. I am using Win7 with AERo disabled and my config is below in my siggy.
Depends on the GPU and shroud casing. They run hotter than CPUs. GPUs can sustain till 100C at load time, the cores are literally forged on the anvils of hell...!
