have to get a external HDD for my cousin. have lots of questions!
1. I have an old(4 years) never used USB 2.0 ide HDD casing. Would it be safe to use it ? i.e buy a 2.5" ide HDD and just stick it in the casing.
2. is the speed affected if the external HDD's interface is sata or IDE ?
3. are IDE 2.5" external HDD available these days? if so what would a 500GB one cost ?
That's it for now.
Thanks
Computer parts search Engine(for india) : http://goo.gl/Sg8Yv
1. It should't be a problem. The real problem would be getting hold of a 2.5" HDD. Better ditch it and get a 3.5" one.
2. External IDE isn't available and eSATA(faster than both IDE and USB) is not present on older PCs.
3. I don't think so. If you find it then it's going to be very expensive.
Nothing is true. Everything is permitted.
That's it for now.
Thanks
Answers
1. Yes it is safe, get a 2.5" ide hdd and you are good to go
2. The interface of the HDD casing is probable USB 2.0 so you will get the maximum bandwidth of a regular usb 2.0 port i.e. 480 mbps
3.You may not get in local shops, try e-bay, you will definitely get there
__________________ | A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
