Old 24-03-2011, 01:12 PM   #1 (permalink)
achtung's Avatar
Default Audio Driver problem in Gigabyte MOBO
I have recently configured an AMD PC with a GIGABYTE mobo.
Problem is, intermittently the audio driver (realtek) is getting uninstalled automatically.
I have formatted the PC again and reinstalled the driver, working fine for some day but again this is occurring.
Kindly give a light on this if anyone have faced this kinda problem..
Thanks in advance..
##aChTuNg##
Experience is what a comb gives you after you lose your hair.
achtung is offline   Reply With Quote
Old 24-03-2011, 01:17 PM   #2 (permalink)
MegaMind's Avatar
Default Re: Audio Driver problem in Gigabyte MOBO
The uninstallation runs on the Screen?
Or u dont see the icon on the taskbar?
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 24-03-2011, 02:56 PM   #3 (permalink)
achtung's Avatar
No uninstallation screens ....Just the speaker icon is gone from system tray..
moreover, when the PC is booting, the booting music is audible, I can hear them, but if I try to play audio file in player like winamp and all, or play u tube video's .. there is no sound..
##aChTuNg##
Old 25-03-2011, 12:28 AM   #4 (permalink)
icon in tray missing doesn't mean Audio driver got uninstalled. its just disabled at startup. even i disabled it & still works fine. BTW, which version are you using?
Old 25-03-2011, 08:40 PM   #5 (permalink)
CA50's Avatar
whats your OS?
1.Go to start>run>type "devmgmt.msc" without the quotes
2.Next expand "sound,video and game controller"
3.check if your audio hardware is listed and is there any unusual marking?
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
- by kool
- by ax3
