23-03-2011, 02:12 PM
Dual ram problem
I am having mobo ASUS M4A78T-E and it has 4 channels for RAM namely A1, B1(red),A2,B2(black).
Manual says that for DUAL CHANNEL i have to put two same RAM either in combination of red or black.
Yesterday I have bought CORSAIR XMS3 2 GB DDR3 1333 MHz RAM(CMX2GX3M1A1333C9 // 9-9-9-24). It comes in a kit of 1 x 2GB and i have bought two pieces.
Previously my mobo has TRANSCEND RAM.
1)Now on putting the two new RAMs on A2 B2 SLOT the system fails to boot. The Chasis fan and cpu fan are running with mobo light on but no beep sound at all.
2)I changed the slot to A1B1 but the result does not change.
3)I put one single RAM it BOOTS.
OS is windows vista 32 bit which is supposed to recognise upto 3.25GB ram.
What is the problem?
23-03-2011, 03:01 PM
Super Moderator
Re: Dual ram problem
Try a CMOS reset first.
Also you mixing the Transcends and Corsairs. Do not.
23-03-2011, 03:21 PM
Fullbring
@avichandana20000: Dont use Transcend RAM with Corsair...
boot using single RAM each...to check whether each RAM module is ok...
then try different combinations of RAM slots....like A1B1 or A1B2 or B1B2 etc
23-03-2011, 04:16 PM
how to do that? by picking up the battery and put it back again?
misinterpreted. i have just mentioned the previous RAM name. I am never trying that insane coktail.
i am not.
i have this in mind and need to do. I can let you know the result tomorrow as i am in office currently.
23-03-2011, 04:30 PM
Fullbring
Yes,remove the CMOS.Then put it back after 60secs
Even I m in office now
23-03-2011, 05:28 PM
Super Moderator
Yes, you reset the CMOS as you mentioned. Make sure the PSU cable is out.
23-03-2011, 05:40 PM
ok. now tell me one thing MOBO MANUAL is saying that for DUAL CHANNEL RAM you should use either A1B1 or A2B2. So will combinations work out?
23-03-2011, 05:43 PM
means 1) the power cable should be disconnected from the back of PSU
2) the 12 v PSU cable disconnected from motherboard
which one?
23-03-2011, 06:28 PM
1) yes.
2) no need. just the power cable should not be connected to the PSU.
also A1B1 means the red slots?
23-03-2011, 07:01 PM
Fullbring
just to make sure u dont get a shock
23-03-2011, 07:50 PM
Originally Posted by Sam
1) A1B1 means the red slots?
yes A1B1 means RED slots.
@Zangetsu you did not answer that.
just want to clear a concept:
while reseting the CMOS the RAMs should be in mobo OR i will install the RAMs after doing the RESET?
24-03-2011, 12:14 AM
Super Moderator
You can leave the DIMMs in or out. Only try combinations with the colors matching for the slots.
24-03-2011, 01:26 AM
^^ ya... similar colors for dual channel mode
24-03-2011, 09:25 AM
RESET the CMOS as asingh advised.
Then installed single module in each slot. Result is -
A1 (RED) BOOTS
B1 (RED) failed
A2 (BLACK) BOOTS
B2 (BLACK) failed
Then started combinations as follows (as per picture starting from left A1 RED,B1RED,A2 BLACK B2 BLACK)
1) A1 B1 (TWO REDs) boot failed
2) A1 A2 (RED & BLACK respectively) system boots
3) B1 A2 (RED & BLACK respectively) boot failed
4) A2 B2 (TWO BLACKs) boot failed
So I have done the installation in A1 A2 (RED & BLACK respectively).
Refer cpu z screenshot
24-03-2011, 10:19 AM
Super Moderator
Not working on any combination. Can you try the new DIMMs else where.
24-03-2011, 10:33 AM
Fullbring
@avichandana20000:How old is your motherboard...I guess problem with DIMM Slots...
24-03-2011, 11:04 AM
Check the rams, does it say "recommended for Inte LGA 1156/1366 setups"?
Insert 1 ram, go to the bios. Set the timings and voltages manually as per specs mentioned on the ram. Save and shut down, insert second ram and boot, see if this works.
If it doesn't, update the bios and give it a shot.
24-03-2011, 03:29 PM
misinterpreted. combination is working at A1A2. refer pics.
bought on 9th jan 2010.
rams are absolutely fine as each of it works in single channel mode.
Hence i am not going to tweak anything any where now. 4 gb is more than enough for 32 bit system and i can feel permormance boost at least by 20 %.
Thanks to every one for suggestion and help.
25-03-2011, 12:23 AM
#19 (permalink)
thats the configuration that works on Intel based PCs. where the 1st & 3rd slot should be filled at first for PC to work.
in your case, even with 2 stick, its running in single channel. ram is ok, problem with DIMM or motherboard.
looking at the details you provided, most likely B1 slot is faulty. clean it & try again if you wish.
