Old 23-03-2011, 03:59 AM   #1 (permalink)
bajaj151's Avatar
Default Tempearture check !!
Should I buy CPU cooler ?
1) Ideal temp (using Everest)
40-42 degree Celsius (Day)
36-40 degree Celsius (Night)
2) Stock fan is noisy (1055T)
Options within budget
-Hyper 212 +
-Hyper N520
-H50
-Other (please suggest)
Information regarding case fan (Haf 922)
1) Front 200mm Inflow
2) Up 200mm outflow
3) Rear 120mm outflow
4) No fans on side panel inflow (Reason: Dust)
- No overclocking
-Will buy graphics card in May
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now   Reply With Quote
Old 23-03-2011, 05:11 AM   #2 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
Default Re: Tempearture check !!
ankit clean ur hsf your temp will drop 5-7 degree, earlier my temp is 30 on idel and 36 on load , but after cleaning my hsf nd my whole cabby current temp is 23-24 on idel nd 30 on load , thats without a ac , but afaik u have a ac in your roon so, just change ur hsf fan only if needed.
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline   Reply With Quote
Old 23-03-2011, 09:51 AM   #3 (permalink)
Super Moderator
asingh's Avatar
That sounds good.
As a rule with the summers kicking in, most of us should do a thorough clean up of our systems.
asingh is online now   Reply With Quote
Old 23-03-2011, 11:28 AM   #4 (permalink)
MegaMind's Avatar
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 26-03-2011, 08:43 PM   #5 (permalink)
bajaj151's Avatar
After adding 2 side fans (Inflow).....Ideal temp drop to 31-33 degree (N)
Is this temp. fine..??
Old 27-03-2011, 01:28 AM   #6 (permalink)
MegaMind's Avatar
coooooooooooooooooooooooooooool
Old 27-03-2011, 04:22 AM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
@ OP - what's your load temps ??
ToPsPeEeD = FaSt BuT StEaDy
Old 28-03-2011, 07:52 PM   #8 (permalink)
bajaj151's Avatar
Using Prime Test....55-58
Old 28-03-2011, 08:29 PM   #9 (permalink)
^^ its a benchmark. stretches the proccy. below 60 for a hexacore is fine.
Old 29-03-2011, 02:50 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
@ bajaj151 - no need to buy a cpu cooler now though if you are thinking about OCing your cpu then get Corsair H50 or Cm hyper N520/620
Old 29-03-2011, 10:39 AM   #11 (permalink)
bajaj151's Avatar
^^ No Ocing...
Old 30-03-2011, 06:24 AM   #12 (permalink)
Fast 'N' Furious
topgear's Avatar
then chill out buddy with the stock HSF
- by kool
- by ax3
