22-03-2011, 06:43 PM
#1 (permalink )
TV Tuner Advice
I want to buy a TV Tuner, probably an External one. But my question is can i watch TV on my Monitor without turning on the rest of my system.
I want to use it with my 22'' LCD monitor which only has a VGA output.
And which one would be a good choice under 1.5k.
At max i can stretch it to 2k.
Plz help.
Spoiler :
i5-2400 |
P8H67M-EVO |
DRW 24B3ST |
WDC Blue 500GB |
VENGEANCE 4GB DDR3 |
FSP SAGA-II 500W |
Zebronics Aviator |
DELL IN2020M |
MS Wired 500 Combo |
Creative A-35 | iBall Rocky Headset
22-03-2011, 08:29 PM
#2 (permalink )
Lord of Problems
Re: TV Tuner Advice
What exactly do you mean by this? How can you use this output as a input from a tv tuner?
UPDATED Cabinet Dust Control:
goo.gl/zl7kz
Gigabyte P67 UD7|i2500K|H70|GSkill 2x4GB|CM HAF X|560GTX Ti|GT 950W|Lycosa|Imation GMS-800
22-03-2011, 09:37 PM
#3 (permalink )
Re: TV Tuner Advice
Yes. if you buy an external (non usb) tv tuner you can watch tv without turning your system on. Buy external tuner that supports the resolution of your LCD monitor. Pixel View Box 8 External TV Tuner sells for Rs 1,950 and has all the requirements you need.
24-03-2011, 01:24 PM
#4 (permalink )
Re: TV Tuner Advice
Originally Posted by
lordirecto
I mean my monitor only has a VGA port. So, how do i connect my TV tuner to it???
Spoiler :
i5-2400 |
P8H67M-EVO |
DRW 24B3ST |
WDC Blue 500GB |
FSP SAGA-II 500W |
Zebronics Aviator |
DELL IN2020M |
24-03-2011, 01:49 PM
#5 (permalink )
Lord of Problems
Re: TV Tuner Advice
^ Oh. I guess you will have to get a component to VGA convertor or coaxial to VGA connector. It depends on your TV Tuner.
goo.gl/zl7kz
24-03-2011, 01:51 PM
#6 (permalink )
Re: TV Tuner Advice
^They are readily avail in all electronic shops...
25-03-2011, 03:34 AM
#7 (permalink )
Re: TV Tuner Advice
Is it not bundled with the TV Tuner. How much would it cost then???
Spoiler :
i5-2400 |
P8H67M-EVO |
DRW 24B3ST |
WDC Blue 500GB |
FSP SAGA-II 500W |
Zebronics Aviator |
DELL IN2020M |
25-03-2011, 12:08 PM
#8 (permalink )
Re: TV Tuner Advice
around 50 bucks
25-03-2011, 12:09 PM
#9 (permalink )
Lord of Problems
Re: TV Tuner Advice
^ Depends on manufacturer. I think a cheapo will do the job for you. I dont see any advantage in going for a high quality convertor.
goo.gl/zl7kz
18-07-2011, 04:24 PM
#10 (permalink )
Re: TV Tuner Advice
Sorry guys for bumping into an old thread. Looking for a good External TV Tuner Card for my Dell ST2220M. Got hold of Tech Com from my cousin. However the audio quality is poor.
I would want to go for another one provided it would be better than current Tech Com one that I have. Budget is around 2k.
18-07-2011, 05:43 PM
#11 (permalink )
Re: TV Tuner Advice
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
19-07-2011, 07:06 AM
#12 (permalink )
"Official HD 7970 Owner"
Re: TV Tuner Advice
saswat23
Plz help.
You can buy a normal Intex or UMAX External TV Tuner from any local computer Shop, min will be 900 - max 1.5k with FM.
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
19-07-2011, 01:41 PM
#13 (permalink )
Re: TV Tuner Advice
d3p5kor
Bro the OP would have already bought this. His last post was in March.
19-07-2011, 01:50 PM
#14 (permalink )
Re: TV Tuner Advice
mithun_mrg
Bro though it looks sleek I think I need to have my PC on all the time to watch TV which maybe additional Power usage. Would prefer not having to switch on the PC and watch TV.
d3p5kor
If the suggestion is for me as well I don't think either are good especially the audio quality.
d3p5kor
^^ BTW you also have bumped into old thread.
Yes I didn't want to create a new thread hence bumped into this.
19-07-2011, 01:56 PM
#15 (permalink )
Re: TV Tuner Advice
Intex one is a total crap in term of audio, but UMAX is a decent one.
IRC Krow
19-07-2011, 03:10 PM
#16 (permalink )
Re: TV Tuner Advice
ajayritik
If u want to watch without switching on the PC then get this@1.5K
Buy AVerMedia | AVerTV Box Genie l Built-in Speaker
19-07-2011, 03:37 PM
#17 (permalink )
Re: TV Tuner Advice
How about Pinnacle?
I'm sure Intex, Tech-com and Umax are not going to be great picks. What's your opinion on these?
19-07-2011, 03:48 PM
#18 (permalink )
Re: TV Tuner Advice
Pinnacle ones r good but costly too & hard to find quality wise i would prefer Pinnacle,Avermedia or Pixelview all the others u mentioned r same
