Old 21-03-2011, 12:41 PM   #1 (permalink)
Default the waiting game
Its been long time i have not played any PC game. Used to enjoy GTA a lot. My PC went kaput long back in 2007 and thus i got my 1st laptop DELL Inspiron 1520. And the only game i play now is Counter Strike on steam.
So from 2007-2011 i have missed many epic game titles (COD,BATMAN,GTA) and many others.
I have been thinking to build a gaming PC and started threads here however every-time something happened and i postponed my decision and decided to wait.
When C2D and quad-core CPU were selling like hot cakes , i was not interested in buying same as new i-Core series was round the corner. Then came the i3,i5 and i7 CPU. I made my mind to buy a quad-core CPU(i5 quad-core CPU) config and was disappointed that only dual core i5 will support on-board graphics and all other quad core CPU will require external graphics card.
Then came the SB CPU and was about to purchase i5 CPU and then this total recall was made because of faulty architecture. Again here we have P and H series thing.
As of now , i think its not the right time to built a gaming PC because of Z68 in near future with i7 ivy bridge , SSD caching etc.
So i have finally decided to get i-core Ivy CPU with z68 chip-set in June or Q2 of this year.
I have been reading every single "buying a PC" thread here and hence i am asking "Is this wait worth waiting for ?" Please post your comments.
Note : I need a on-board GPU because even if i am buying a GFX card , in-case anything goes wrong ,at-least i can start my PC.
noob is offline   Reply With Quote
Old 21-03-2011, 12:47 PM   #2 (permalink)
Default Re: the waiting game
Wait for X series mobos.
Faun is offline   Reply With Quote
Old 21-03-2011, 12:49 PM   #3 (permalink)
****...whats X now ?? whats special in it which is worth waiting for ? I am now tired of this waiting.
Old 21-03-2011, 12:54 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Name your budget and we can advise. Waiting is...dumb.
Also if you seriously want to game a GPU is necessary. We all do the same.
asingh is online now   Reply With Quote
Old 21-03-2011, 01:02 PM   #5 (permalink)
It is P + H. I am not able to find the article.
Old 21-03-2011, 01:03 PM   #6 (permalink)
YEs, I second this. However for me on-board Graphics is mandatory. In-case anything goes wrong with GFX card , i can at-least start my PC.
Hope you got my point.
Speaking about budget , I am not sure as of now. Because revised boards are hard to get in mumbai market.
I want a super cool and ZERO Noise PC. Long back i had 2.4 GHZ prescott CPU and man...what a noise...my parents used to tell that it sounds like a water pump of our society and its true. Mind ****ing noise.
Later i came to know that intel prescott CPU gets heated a lot.
how much will it take to build a gaming PC considering that i wont over-clock and ready to spend more on basic stuff now and buying a graphics card 1-2 months later.
How much those i5 SB CPU heats ? what about the noise in this case ?
is this not Z68 ??
Old 21-03-2011, 02:08 PM   #7 (permalink)
is this not Z68 ??
Yeah, right. I confused Z with X.
Old 21-03-2011, 03:22 PM   #8 (permalink)
So should i get a PC now or wait for Z68 considering the long wait i had , i think its better to buy latest Z68 than buying current hardware.
Old 21-03-2011, 05:06 PM   #9 (permalink)
MegaMind's Avatar
If u wait for a few more yrs, u can get i11...
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 21-03-2011, 05:12 PM   #10 (permalink)
yeah man..
i am confused as of now.
Old 21-03-2011, 07:08 PM   #11 (permalink)
Lord of Problems
lordirecto's Avatar
What do you mean if something happens, you can atleast start the computer? Nothing will go wrong like you imagine. So instead of waiting and missing every technology, make up your mind and go in for the best and highest config that your budget will allow. Also, if you seriously want some decent performance from your computer, go in for a dedicated gfx card.
Just as a precaution, you can invest in a low cost GPU in case you are too unsure about your main gfx card failing.
UPDATED Cabinet Dust Control: goo.gl/zl7kz
Gigabyte P67 UD7|i2500K|H70|GSkill 2x4GB|CM HAF X|560GTX Ti|GT 950W|Lycosa|Imation GMS-800
lordirecto is offline   Reply With Quote
Old 21-03-2011, 07:17 PM   #12 (permalink)
yes i will get a graphics card..but not now..may be after 1-2 months later.
Hence i need integrated graphics.
Also whats the advantage of Z68 over H or P chipset available now in market except SSD caching. ?
Any good Rev B3 mobo in market ? esp Mumbai ?
Old 21-03-2011, 07:23 PM   #13 (permalink)
Lord of Problems
lordirecto's Avatar
Z68 can support both onboard gfx and also overclocking. Where as H67 supports onboard gfx alone. P67 can only support overclocking.
Look for Asus or Gigabyte mobo as per your budget.
Old 21-03-2011, 07:25 PM   #14 (permalink)
plz post links of both P n H mobos....
Old 21-03-2011, 09:02 PM   #15 (permalink)
Jaskanwar Singh's Avatar
tell how much can you spend max?
Old 21-03-2011, 09:05 PM   #16 (permalink)
40K now with-out GFX card.
Will buy gfx card next month as i will get my 15K adsense money from google by that time. however i am from mumbai and not sure about B3 mobos availability
Old 21-03-2011, 09:06 PM   #17 (permalink)
Tensor
@anil If you want to help yourself, first convince yourself to buy a rig, then tell us your max budget.
Cheers!!
Originally Posted by Blizzard
...and the heavens shall tremble...
Diablofans
Force Strategy Gaming
YouTube
Xfire
Gaurav Bhattacharjee is offline   Reply With Quote
Old 21-03-2011, 09:08 PM   #18 (permalink)
Cheers!!
if z68 has better performance than current config you guys suggest, i will wait..or else buy in next 10 days max for sure.
1. Gaming and HD Movies
2. Need ZERO sound cool PC even while gaming
3. 22-24Inch monitor for HD movies and games ( LED possible ?)
Old 21-03-2011, 09:12 PM   #19 (permalink)
Tensor
Buy now. No huuuge performance increase will come with the Z68 chipset.
1. Check. Fine.
2. That'll mean liquid-cooling. It'll burn quite a big hole in your pocket.
3. Possible.
Diablofans
YouTube
Xfire
Old 21-03-2011, 09:26 PM   #20 (permalink)
By ZERO sound i mean that not much noise compared to my 2.4 ghz prescott CPU. it used to sound like our society water pump and i used to get headache after hr of gaming...even when idle , it sounded same.
Strong Build quality of cabinet with better cable management and proper air flow (120 mm+ fans with less noise) + good PSU (again with big fan and less noise)
I hope you got my point behind ZERO noise
Possible in 40K range ?
I dont need UPS , Speakers , Keyboard, Mouse.
Old 21-03-2011, 09:29 PM   #21 (permalink)
Tensor
By ZERO sound i mean that not much noise compared to my 2.4 ghz prescott CPU. it used sound like our society water pump and i used to get headache after hr of gaming...even when idle , it sounded same.
yep possible.
Diablofans
YouTube
Xfire
Old 21-03-2011, 09:39 PM   #22 (permalink)
Fine....here is the NEW thread as per rules.
[HELP]Building a gaming rig after 3+ years
Old 21-03-2011, 10:13 PM   #23 (permalink)
You have waited so long then wait few months more for Z series.
Old 23-03-2011, 07:37 PM   #24 (permalink)
with a 40k budget, its pointless going for SB, I strongly recommend that you go for an AMD based rig, save up for an awesome card. A decent Phenom II quad and a HD 6950 would be awesome
btw, marathi kavita doing great, congrats
Win hardware worth 11k!!
rajan1311 is offline   Reply With Quote
Old 24-03-2011, 07:37 PM   #25 (permalink)
Adam young
sukesh1090's Avatar
what about bulldozer from amd?why u are not suggesting it.
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 25-03-2011, 12:24 AM   #26 (permalink)
^^ let it get launched, then we can think about recommending.
Old 25-03-2011, 05:32 PM   #27 (permalink)
Adam young
sukesh1090's Avatar
yup.you are right
-Rifleman's Creed
- by kool
- by ax3
