Old 20-03-2011, 10:07 PM   #1 (permalink)
kool's Avatar
Exclamation How to unlock BitLocker & Plz Solve BLUE screen NDIS_SERVER..!!!
Guys,
i'm really tensed, from last 2 days i'm unable to login in normal mode in win7, as i'm getting this error message with blue screen.Only able to login via SAFE MODE. Check attached image. By the way i've 4 partition in my system where D drive is locked with bitlocker, and i've dual OS Win XP and Win 7, now when i login to winXP, it only ask to FORMAT "D" drive. and D drive is very important for me, as all my college pics are saved in it.
So guys, plzzz help me to solve this BLUE SCREEN PROBLEM under win7 or just solve to unlock that drive in mode in XP.
Error Message:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
BUGCODE_NDIS_DRIVER
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.
Technical Information:
*** STOP: 0x0000007C
Beginning dump of physical memory
Physical memory dump complete.
Contact your system administrator or technical support group for further
assistance.
kool is offline   Reply With Quote
- by kool
- by ax3
