Old 18-03-2011, 05:16 PM   #1 (permalink)
Default System turns off all of a sudden
Hi
My problem is that the system turns off all of a sudden. When I press the On button it doesnot start. I have to turn off the UPS and turn it on again. Then if I press the on button it starts.
What could be the problem?
OS windows 7. Config: Intel Core 2 Quad 8400 @ 2.66 GHz./ 2 GB RAM./ Nvidia gforce 9400 / Power supply: Model XS-300FB/ UPS: APC 600VA
Aanand is offline   Reply With Quote
Old 18-03-2011, 05:55 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: System turns off all of a sudden
and the Power Supply..?
asingh is online now   Reply With Quote
Old 18-03-2011, 06:34 PM   #3 (permalink)
Power supply: XS-300FB
Size PS2 Single
Input Voltage 230 V
Connectors Mother Board Connector 20+4 Pins - 1
Core Voltage Connector 4 Pins - 1
SATA Power Connector - 2
4 Pin Power Connector - 3
FDD Power Connector . - 1
Voltage
Ampere Rating
Voltage Amperage
+3.3 V - 11.0A
+5 V - 13.0A
+12 V - 9.0A
-5 V - 0.5A
+5 VSB - 1.5A
Prime Source - XS-300FB - Entry Level Power Supply for PC
Old 18-03-2011, 07:43 PM   #4 (permalink)
MegaMind's Avatar
Before this prob, was ur pc workin fine????
Ur PSU definitely needs a change...
Can u enter the bios?
If yes, enter bios and check the procy temp.....
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 18-03-2011, 08:13 PM   #5 (permalink)
I have this prob since I bought the PC. As the problem occurred occasionally - once in a week or so i didn't care for it. Now also it occurs like that only. Previously I thought that it was due to power problem at our place.
Process Thermal Margin: 37 C
Motherboard temperature 43 C
MCH temperature 45 C
ICH temperature 82 C
Win7 Ultimate 32/Intel CLASSIC DG43NB/Intel Core 2 Quad 8400 @ 2.66 GHz/4 GB RAM(2x2GB)/Nvidia Geforce 9400/Seagate 2TB & Seagate 500GB/LG16X/i-ball sprinter500/Samsung740N & SA300/APC ES650VA
Old 18-03-2011, 08:22 PM   #6 (permalink)
MegaMind's Avatar
PSU may be the culprit....
now try removing the GPU and connect the monitor to mobo and switch on....
Old 18-03-2011, 08:54 PM   #7 (permalink)
Super Moderator
asingh's Avatar
Try to reconnect everything once. Else most probable PSU.
Old 19-03-2011, 03:25 PM   #8 (permalink)
Hi, I also came to the conclusion that the PSU is the culprit.
I have replaced the 300 W Prime Source SMPS with I-ball Sprinter -500 W. Hope My system will work fine.
Old 19-03-2011, 11:08 PM   #9 (permalink)
whats the cost of the new PSU? theres better option available but maybe you went for shopkeepers words. all the best. just hope this last for a couple of years.
Old 31-03-2011, 01:50 PM   #10 (permalink)
Thanks guys!
The I-Ball sprinter 500 W costs Rs. 2400/-
After the replacement the problem solved.
Old 31-03-2011, 04:32 PM   #11 (permalink)
Be sure to use a proper UPS and also dont directly shutdown your PC. Things like that damage PSU.
- by kool
- by ax3
