Old 18-03-2011, 02:48 AM   #1 (permalink)
iGoogle
guru_urug's Avatar
Default RAM timing probs
PC config
amd athlon II x4 630
msi 785gm e51 mobo
4GB ddr3 RAM corsair 1333mhz
9800GT 1GB card
500+160 GB hdd
I had a 2GB ddr3 1333mhz ram stick earlier, and later added the other 2GB stick..Both are the same model and brand-corsair
The thing that stumps me is that even though both have same timings, their TRFC values are diff in BIOS one is 107 and other is 75
Is this ok? can two ram sticks of same model and brand have diff trfc values or was I sold a defective ram module??
Please help, thanks
guru_urug is offline   Reply With Quote
Old 18-03-2011, 03:07 AM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: RAM timing probs
It won't effect performance but it might effect stability.
It can be controlled from BIOS.
Set them both to 75/107. (Not all will have this option)
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 18-03-2011, 07:02 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
since you have bought the ram try running some heavy mem hungry apps and games for 3-4 hours constantly and if your system is stable then there's nothing to worry about.
ToPsPeEeD = FaSt BuT StEaDy
Old 18-03-2011, 09:50 AM   #4 (permalink)
Super Moderator
asingh's Avatar
You have the option to change the value..?
asingh is online now   Reply With Quote
Old 18-03-2011, 11:16 AM   #5 (permalink)
iGoogle
guru_urug's Avatar
Thanks guys....just one more thing when I check the part number using cpuz...both rams have diff number
one has
VS2GB1333D3
and other is
VS2GB1333D4
is this ok?
Old 18-03-2011, 11:39 AM   #6 (permalink)
Super Moderator
asingh's Avatar
You should be fine.
Old 18-03-2011, 11:17 PM   #7 (permalink)
iGoogle
guru_urug's Avatar
Thanks @asingh ....relieved to know that.
Thanks to everyone else too
- by kool
- by ax3
