Old 18-03-2011, 12:17 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default CM USP 100 Front Panel issue
Hey i bought USP 100 yesterday and for the first time i tried using front panel of my DG33FB onboard audio but i can only hear sound coming out of left side and right side is completely mute for some reason.
Rear ports work fine.
I tried using both connectors in cabinet AC97 & HD Audio.
Tried experimenting with varius options in control panel also.
If it matters my Rear MIC also doesn't work since i bought that board (3yrs back) but front panel mic worked.
1) Do you guyz think its an intel onboard audio related issue or something wrong in cabinet front panel ?
2) Is it possible that rear ports are good and intel front panel on mother is faulty ?
hardhardware is offline   Reply With Quote
Old 18-03-2011, 02:14 AM   #2 (permalink)
bajaj151's Avatar
Default Re: CM USP 100 Front Panel issue
If u have Realtek HD Audio Manager installed....
Disable front panel detection and see if it works..
Phenom x6 1055T 3.75 GHz | MSI 890GXM G65 | Corsair XMS3 2*4GB 1600mhz | BenQ E2200HD | Xbox 360 Controller | Seagate 2TB | CM HAF 922 | Corsair VX 550 | Logitech MX 518 | Logitech Wireless Keyboard | Sapphire 7850 OC
bajaj151 is online now   Reply With Quote
Old 18-03-2011, 07:02 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
make sure front panel audio is enable in bios settings !
ToPsPeEeD = FaSt BuT StEaDy
Old 18-03-2011, 12:30 PM   #4 (permalink)
MegaMind's Avatar
connect AC97, n go to bios and set front panel as AC97...
Also try reinstalling audio drivers...
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 18-03-2011, 06:41 PM   #5 (permalink)
as mention in my first post i have already tried using AC97 ,reinstalling drivers etc
I don't have option in bios to set AC97 or front panel, i just changed these from realtek mgr.
Old 18-03-2011, 07:40 PM   #6 (permalink)
MegaMind's Avatar
did u see the onboard audio option in bios?
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/138127-cm-usp-100-front-panel-issue.html
Thread CM USP 100 Front Panel issue | Digit Forum | BoardReader This thread Refback 15-07-2011 10:32 PM
- by kool
- by ax3
