16-03-2011, 01:54 PM
Can I use this RAM module?
I am currently having a pair of XMS3 C9 memory module's, I was searching a 2 GB one, and found this on SMC. It's C8, but DDR3 1600, so can I use it?
Please have a look,
Corsair CMP6GX3M3A1600C8 2GB DDR3 Memory
and I am using this,
Thanks in advance.
i7 950►SABERTOOTH►8GB RAM►GTX560►690II +►TX650
SGS II
16-03-2011, 02:45 PM
Super Moderator
Re: Can I use this RAM module?
They will run, but no use mixing latencies. One will downclock.
16-03-2011, 04:08 PM
Aren't the both of them 9-9-9-24?
SGS II
18-03-2011, 01:44 AM
"Official HD 7970 Owner"
IMO if you have budget then, go for Corsair 2X2GB 1600C9 1.65v 9-9-9-24 - Rs. 2.4k.
But i doubt that can't change the Latency & make all three work in the same latency.
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
18-03-2011, 09:55 AM
Super Moderator
I think C8 and C9's would have different latencies. To lazy to look it up.
18-03-2011, 10:03 AM
Manchester United <3
Yes .
You can change the latencies. Its fairly simple.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
18-03-2011, 01:44 PM
he wants to run ram in triple ch. so he's going for an extra stick.
18-03-2011, 02:22 PM
@Sam, Yep, you are right. I wanna buy another stick for triple channel.
@d3p5kor, It's not about budget. 8GB? Well I don't think I need that much memory for my purpose
@Ishu- You sure that C9 and C8 have different latencies?
I'll check it anyway, and I think if they have same latency then I could easily go for a C8
SGS II
18-03-2011, 02:52 PM
C9 and C8 signify latencies right?
So obviously they are different.
18-03-2011, 02:56 PM
C9 = 9-9-9-27
C8 = 8-8-8-24
So they are different. If OP can match the existing RAM timings with the latest RAM, then i don't think its problem going for a C8.
IRC Krow
18-03-2011, 03:01 PM
90% it will be OK but it is recommended to go for similar modules. Just go for C9.
Different RAM modules *CAN* cause random BSODs.
18-03-2011, 07:48 PM
I tried local stores, but they don't wanna give a single 2 GB module and also saying it won't be inside warranty if I buy a single module. Not all the shops but good one's are saying this. I don't want another 4 GB, while a 2 GB would be more than enough...m confused!
SGS II
