Old 13-03-2011, 06:08 PM   #1 (permalink)
Default Need advice for better thermal paste
currently my 955 BE CPU temps are 39c idle
and 56c load.
using cooler master thermal fusion 400 with hyper212 plus.
are my temps high or normal?
Members please suggest me very good thermal paste that would bring down these CPU temps.
Phenom II 955@4.2Ghz@1.35V |785G|coolermaster Hyper 212+|Mushkin blackline DDR3 4GB @7-8-6-18 1600Mhz |Coolermaster 600W Extreme| HD5770 @stock|Coolermaster HAF 922
waghanuroop1 is offline   Reply With Quote
Old 13-03-2011, 07:33 PM   #2 (permalink)
Tensor
Default Re: Need advice for better thermal paste
those are normal dude.
my slowwwww 1.8GHz dual core idles at 50c and goes to 75-80c on full load.
so stop worrying.
Gaurav Bhattacharjee is offline   Reply With Quote
Old 13-03-2011, 08:43 PM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes. those temps are normal. and it's a f'ing overclocked CPU. you also have a nice aftermarket cooler. if you want to bring the temps down, look for better cabinet and add few fans for cooling.
desiibond is offline   Reply With Quote
Old 13-03-2011, 11:15 PM   #4 (permalink)
Thanks guys for helping me out.
But which thermal paste do you all advice or which you would prefer to use?
Old 14-03-2011, 02:22 AM   #5 (permalink)
MegaMind's Avatar
Thermal fusion 400 is a great paste... check the link,
http://benchmarkreviews.com/index.ph...&limitstart=12
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
Old 16-03-2011, 12:13 AM   #6 (permalink)
Lord of Problems
lordirecto's Avatar
I have some industrial grade thermal paste that I have used on my laptop, and I see a difference of 10 degree C. Temperature is hovering around 60 now.
lordirecto is offline   Reply With Quote
Old 16-03-2011, 09:55 AM   #7 (permalink)
Super Moderator
asingh's Avatar
Woah...! What is this stuff to create a delta of 10C.
asingh is online now   Reply With Quote
Old 18-03-2011, 11:10 PM   #8 (permalink)
MegaMind's Avatar
Thermal fusion 400 gave me a 20 deg descent...
- by kool
- by ax3
