Hi Guys,
Recently i have purchased a 2nd 500 gb HDD from Segate, and i already own 1 500 gb of HDD but i would like to know how to install the second 500 GB and make a partition??? should i go for a RAID config or just the simple install....what would you suggest....i would like to make a fresh format also windows 7 32bit i will back my data before doing so....or is there any other way to do so....please advise....thanks in advance...its urgent
my pc config:
Phenom 2 X4 965 BE @ 3.4 Ghz
Gigabyte 890GPA UD3h mobo
G skill Ripjaw 1333 Mhz 2X2 (4GB) DDR3
Shappire Radeon HD 6870 1GB
Corsair TX750 watt
