Old 08-03-2011, 09:17 PM   #1 (permalink)
ithehappy's Avatar
Default 4 GB RAM showing only 2 GB? Please Help.
Hey guys I suddenly noticed today that after installing my new GPU the RAM isn't showing 4 GB under BIOS and Windows Device Manager, however in CPU-Z it's showing 4096 MB. I've installed them in correct places in my Mobo, but still! Please help me as your earliest.
Have a look at the screens.
Uploaded with ImageShack.us
*image deleted -- had user product ID.
Anil
i7 950SABERTOOTH8GB RAMGTX560690II +TX650
SGS II
ithehappy is offline   Reply With Quote
Old 08-03-2011, 09:25 PM   #2 (permalink)
Stuck in Time...
Vyom's Avatar
Default Re: 4 GB RAM showing only 2 GB? Please Help.
Start Task Manager. Goto, Performance tab. And post that screenshot too.
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 08-03-2011, 09:34 PM   #3 (permalink)
ithehappy's Avatar
Okay, the total is 2039 MB as far I can see it. What is Commit MB? It's showing 1135/4078!
Added the msinfo32.
Please help guys, I am panicked.
SGS II
Old 08-03-2011, 10:17 PM   #4 (permalink)
ithehappy's Avatar
Yes please look at the above photos, I've already done that, it's showing only 2GB, but I've 4GB installed!
SGS II
Old 08-03-2011, 10:25 PM   #5 (permalink)
Stuck in Time...
Vyom's Avatar
Commit (MB) is the total of RAM and Virtual Memory of a system.
For long answer refer, Task manager; commit charge? peak? Performence? - Yahoo! Answers
It seems your windows 7 is accepting only 2 GB of RAM! Strangely, CPU-Z shows all 4, so the RAM's are correctly installed.
I am not an memory expert.. but following article may help. Its a little technical. But I suppose, you can get some answers here.
Who ate my memory? - Where are we going, and what's with the handbasket? - Site Home - MSDN Blogs
Old 08-03-2011, 10:41 PM   #6 (permalink)
ithehappy's Avatar
Originally Posted by thetechfreak View Post
Make sure you have properly fitted. RaM.
Try refiting.
They are absolutely well fitted, checked thrice now. I am becoming mad now
SGS II
Old 08-03-2011, 10:47 PM   #7 (permalink)
Weird. Does your motherboard come with integrated GPU ?
As far as I know, i7 motherboards don't have integrated GPU. So the IGP is not using half the RAM. What else could be it ? Try refitting the RAMs as suggested. Also if you have more than one RAM modules, try one-by-one.
If that fails, try your old CPU & post its results.
pauldmps is offline   Reply With Quote
Old 08-03-2011, 11:03 PM   #8 (permalink)
ithehappy's Avatar
Well I remember one thing clearly when I was reassembling the Proccessor yesterday my I took a clean cloth and was removing the old Thermal compound and once the cloth got stuck in to the CPU socket pins, and I cleared the cloth by pulling it. Is there a chance of bent CPU Socket pins and for that is this problem occurring?
I tired to place the RAM module's in B1 and C1 slot instead of A1 and B1 and the BIOS now detects 4088MB! I tried with A1 and C1, BIOS detected 2040MB, so I guess the A1 slot is not working.
SGS II
Old 08-03-2011, 11:08 PM   #9 (permalink)
Super Moderator
asingh's Avatar
Windows OS does that. Mine shows 6GB when I have 4. What does the BIOS show..?
asingh is online now   Reply With Quote
Old 08-03-2011, 11:10 PM   #10 (permalink)
So you've successfully isolated the problem.
Also how dare you use cloth to wipe CPU contacts ?
Old 08-03-2011, 11:14 PM   #11 (permalink)
ithehappy's Avatar
So that is the problem? It's because of CPU Socket Pin got damaged or something. right? What to do now?
@Asingh, BIOS shows 2040MB when the Modules are at recommended A1 and B1 slots, it shows 4088 MB when they are at B1 and C1 slots.
SGS II
Old 08-03-2011, 11:24 PM   #12 (permalink)
1. I don't think it has anything to do with CPU contacts, because it is working in different slot. I may be wrong here.
2. Is there any visible damage in the A1 slot ? Try using a single module in the A1 slot & see if the PC boots.
3. If the A1 slot is damaged, then you're fu(ked.
Old 08-03-2011, 11:29 PM   #13 (permalink)
Super Moderator
asingh's Avatar
I think I am fu(ked up bad, right?
Relax.
Give me your full motherboard model number. Else update it with your signature. Also is this all happening on stock settings..?
EDIT:
Can we stop the misnomer for the EFFF word. I am sure you educated lads have more words in your vocabulary. Thanks.
Old 08-03-2011, 11:54 PM   #14 (permalink)
ithehappy's Avatar
@asingh, I am really sorry. I was really puzzled.
Anyway, I opened the Processor, there were 2 or 3 pins on the CPU Socket lying down as I though earlier, it was clearly visible with even my naked eyes, so I used a empty gel refill to pull them up, then re-installed the Processor and cooler, system booted, RAM module's installed at A1 and B1, and now it does show 4080 MB.
Now I very much know that the CPU Socket is all messed up, and this one is so easily attachable or detachable. So should I get a new CPU Socket?
SGS II
Old 09-03-2011, 12:18 AM   #15 (permalink)
Super Moderator
asingh's Avatar
GULP....!
What in the world were you doing to get bent CPU socket pins. Just install the DIMMs in alternate fashion and keep the board. I think you managed to straighten the pins. Be careful man. You must have tried an incorrect dock once, but stopped, though resulted in a few bent pins. That is expensive hardware. You are fine now.
Old 09-03-2011, 12:24 AM   #16 (permalink)
ithehappy's Avatar
Thanks mate. Now I am relieved. But is a New CPU Socket for this Mobo available?
SGS II
Old 09-03-2011, 03:15 PM   #17 (permalink)
ithehappy's Avatar
Might be!
---------- Post added at 03:15 PM ---------- Previous post was at 02:38 PM ----------
Here is the official reply from ASUS,
"Unfortunately, it is impossible for a person to replace the CPU socket in a mother board. It may even be impossible to replace a CPU socket in the factory that makes mother boards, once other parts are attached to the mother board.
The number of connections and the manner in which they are soldered in place makes it impossible for a CPU socket to be mounted, except with very special equipment. Unless you are able to bend the pins back into the correct position with a very small tool, you will need to replace the entire mother board."
So it's clear that a New CPU Socket Pin Board IS NOT available.
SGS II
Old 10-03-2011, 06:10 AM   #18 (permalink)
Fast 'N' Furious
topgear's Avatar
Congrats ! I think you solved your problem and there's no need to worry anymore though take proper care in the future while playing with these delicate components
HWhat should I do? Keep running the Motherboard like that or should I go to a Goo d Service Centre for repairing? Coz I was thinking that the RAM problems might have gone but there might be other problems which I can't realise now.. Am I right?
Please advice me what to do buddy. I am kinda scared.
Thanks in advance.
Just keep the mobo running like that as you have already fixed it and test it with some heavy cpu intensive app/benchmark tools for prolonged period of time - say a 4-6 hor crysis/metro2033/BFBC2 session in the morning - a 4-6 hour prime/OCCT test or if possible keep running the system for 24 hours continuously for a day and try converting some huge HD files to small size ( say 700MB ) using cpu as the encoder - if you find no prob with those test your system is alright and ready to rock with GTX560 Ti
ToPsPeEeD = FaSt BuT StEaDy
Old 10-03-2011, 10:26 AM   #19 (permalink)
Game on !!!
anupam_pb's Avatar
Install a 64 bit OS
My PC config : Intel core i3 2.93 Ghz, 2 x 2GB DDR3 1333Mhz, Intel DH55TC, XFX Radeon 5670 1 GB GDDR5, Windows 7 Ultimate 64-bit, LG DVD writer, Corsair CX430W, SAMSUNG 17" LCD (4:3); Samsung Galaxy Y
anupam_pb is offline   Reply With Quote
Old 11-03-2011, 07:28 AM   #20 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ read the entire thread properly - it's not because of OS rather than it was a HW issue which OP has fixed.
- by kool
- by ax3
