Old 07-03-2011, 08:16 PM   #1 (permalink)
Dust in the Wind
Skud's Avatar
Default Help Me Buy a Mouse
Guys I want to buy a mouse. Primary concerns are ergonomics and gaming. Suggest me something for prolonged use. I have short-listed a few:-
1) RAZER ABYSSUS
2) Logitech MX518
3) Arctic M571 Laser
4) GIGABYTE GM-M6800
My budget is 1.2-1.3K. Please pour in the suggestions.
---------- Post added at 02:46 PM ---------- Previous post was at 02:41 PM ----------
Another thing, is buying a 400-500 bucks Mousepad necessary for regular usage of say around 10-12 hours?
Gaming Rig:
i7 2600K || CM N620 || ASUS P8Z68 Deluxe || 2x4GB GSkill RipjawsX 1600MHz || OCZ Vertex 3 120GB || Razer Cyclosa Bundle || Sapphire 6950 1GB || BenQ G2420HD || Corsair HX750 || Lancool K62 || Altec Lansing VS2421 || ASUS Vulcan ANC || NZXT Sentry Mesh
HTPC Rig:
C2D E7400 || Gigabyte EP45-DS3R || 2x2GB DDR2 800 || 9TB || MS Wireless Desktop 2000 || Gigabyte 5770 || Samsung 32" || Seasonic SII 520W || Silverstone LC10
Samsung Galaxy R I9103
Will be off/irregular for a month...
Skud is offline
Old 07-03-2011, 08:22 PM   #2 (permalink)
Fluidic design!!!
himangshu's Avatar
Default Re: Help Me Buy a Mouse
Logitech MX518 @1.2k
ASUS P5K-VM|Intel C2D E7200 2.53 GHz|Kingston 3gb DDR2 800MHz|XFX GT240 1gb|WD 160gb, Seagate 500gb|CM 350W PSU|Zebronics Antibiotic|BenQ G2220HD|Moser Baer DVD-RW|Logitech MX518
himangshu is offline
Old 07-03-2011, 09:18 PM   #3 (permalink)
Wise Old Ghoul
Piyush's Avatar
Abyssus will be my choice
and regarding ur Mouse pad
on which surface u r going to use this mouse?
Steam:http://steamcommunity.com/id/alien007
"What kind of tomorrow should I dream about tonight"
--Get Backers
Piyush is offline
Old 07-03-2011, 09:23 PM   #4 (permalink)
Tensor
My suggestions for both mouse and pad:
Razer Abyssus @1.375k <---Same as Piyush says.
Razer Kabuto Pad @0.57k
Gaurav Bhattacharjee is offline
Old 07-03-2011, 10:19 PM   #5 (permalink)
Dust in the Wind
Skud's Avatar
table top. plywood. the surface is not very smooth though, apparently after use of mouse without any mousepad.
Gaming Rig:
HTPC Rig:
Skud is offline
Old 07-03-2011, 10:21 PM   #6 (permalink)
Tensor
Originally Posted by Skud View Post
table top...
no pad you mean???
you're razer will be ruined..
Old 07-03-2011, 10:53 PM   #7 (permalink)
Dust in the Wind
Skud's Avatar
no no just a generic pad... nothing special... got while assembling the PC...
---------- Post added at 05:23 PM ---------- Previous post was at 04:58 PM ----------
How about Rantopad???
Gaming Rig:
HTPC Rig:
Skud is offline
Old 08-03-2011, 09:33 AM   #8 (permalink)
Wise Old Ghoul
Piyush's Avatar
better get a mouse mat
how much u can spend on mat?
--Get Backers
Piyush is offline
Old 08-03-2011, 10:05 AM   #9 (permalink)
Dust in the Wind
Skud's Avatar
mouse+pad = 1.6 - 1.7K
give me the best combo within this range...
Gaming Rig:
HTPC Rig:
Skud is offline
Old 08-03-2011, 10:18 AM   #10 (permalink)
Wise Old Ghoul
Piyush's Avatar
then go for Gaurav's combo
--Get Backers
Piyush is offline
Old 08-03-2011, 10:28 AM   #11 (permalink)
Dust in the Wind
Skud's Avatar
Itwares is giving a combo of Rantopad H1 & MX518/Abyssus @ Rs. 1650/- plus 75/- shipping. How are Rantopad mats?
Gaming Rig:
HTPC Rig:
Skud is offline
Old 08-03-2011, 11:48 AM   #12 (permalink)
Wise Old Ghoul
Piyush's Avatar
dunno about rantopad...
never heard...
--Get Backers
Piyush is offline
Old 08-03-2011, 11:52 AM   #13 (permalink)
Tensor
never heard...
ya me too.
skud i would suggest you get the mouse (and pad if you want) from the SMC links i gave.
i doubt they'll even charge for shipping for the tiny-sized order.
Old 08-03-2011, 12:43 PM   #14 (permalink)
Dust in the Wind
Skud's Avatar
@ Gaurav
How is Razer Goliathus?
Gaming Rig:
HTPC Rig:
Skud is offline
Old 08-03-2011, 12:49 PM   #15 (permalink)
Tensor
@ Gaurav
Its cool.
Razer Goliathus @0.875k
But really, I wouldn't know the difference between a normal and a gaming pad. Mine is PS/2 mouse and a generic pad and i still kick people's ass in Quake III multiplayer.
Old 08-03-2011, 01:01 PM   #16 (permalink)
Dust in the Wind
Skud's Avatar
More than gaming I am bothered about the comfort and well-being of my hand and wrist. I will buy a pad if only it helps in the prolonged usage and ergonomics.
BTW, Razer Goliathus @ 500/- & Abyssus @ 1300/- from ITWARES plus shipping. That's almost 2K in total.
Gaming Rig:
HTPC Rig:
Skud is offline
Old 08-03-2011, 01:14 PM   #17 (permalink)
Tensor
then go only for mouse now.
if you feel that the generic pad is not doing well then consider something.
Old 08-03-2011, 02:07 PM   #18 (permalink)
Wise Old Ghoul
Piyush's Avatar
^^yup
better idea
--Get Backers
Piyush is offline
Old 08-03-2011, 06:45 PM   #19 (permalink)
Dust in the Wind
Skud's Avatar
only problem is that i have to pay the shipping charges twice.
Gaming Rig:
HTPC Rig:
Skud is offline
Old 08-03-2011, 07:58 PM   #20 (permalink)
hi Razer Abyssus High Precision Mouse is one of the best gaming mouse and if u can pay a lil more around 200 Bucks u can get very awesome mouse pad razer kabuto.u can find all the details about other brands at one place from where i find this ratetorate.in.
techplugger is offline
Old 08-03-2011, 08:20 PM   #21 (permalink)
Dust in the Wind
Skud's Avatar
Costlier than other sites. Thanks anyway.
Gaming Rig:
HTPC Rig:
Skud is offline
Old 09-03-2011, 12:04 PM   #22 (permalink)
Tensor
Just go for the Abyssus mouse. Get a new pad once the generic one has worn out.....that'll be like...5-6 years later or more.
Old 09-03-2011, 01:05 PM   #23 (permalink)
Super Saiyan
Goten's Avatar
Read many comments....Ur budget is 1.2K.
And the thing is you are not going to buy a mouse pad.....So lazer mice are out of the question because on higher dpi settings...without a good mouse pad....Ur mouse will lag and will be inaccurate.
So its better to go with MX518 which is one of the best optical mouse and a long runner.
Has proven itself to be reliable.
Peace~~~!
Newest Purchase :- Razer Deathadder 3.5G and Razer Speed Control Goliathus Mouse Mat.
Goten is offline
Old 10-03-2011, 04:25 PM   #24 (permalink)
TechFanatic
sparx's Avatar
The Razer Abyssus has 3500dpi sensor compared to MX518 1800dpi, but MX518 extra thumb buttons compared to Abyssus with 3 mouse button(1 click wheel). Its your choice
sparx is offline
Old 13-03-2011, 08:34 AM   #25 (permalink)
Manchester United <3
Ishu Gupta's Avatar
How do you hold your mouse? That's important. Check the razer site to know your grip.
And Abyssus 3500DPI version has very bad jittering issues on most pads. Don't buy it.
I would suggest MX518 of those. Its a little big and ugly. If you are a palm user or have large hand, then its good. The sensor is worse than Abyssus
If you can increase your budget get the Deathadder. Its has the same sensor the Abyssus has, but a firmware update can fix the jittering issue
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline
Old 13-03-2011, 08:49 AM   #26 (permalink)
Dust in the Wind
Skud's Avatar
I have a palm grip, but not a large hand. Increasing budget is not a problem provided there are benefits in long-time usage as stated earlier. Is DA better than MX518 is respect of ergonomics?
Gaming Rig:
HTPC Rig:
Skud is offline
Old 13-03-2011, 09:28 AM   #27 (permalink)
Ishu Gupta's Avatar
They are both palm. *I* think that Deathadder is more ergonomic than the MX518 (which is huge and bulky).
I suggest you go to a shop (or friend) and check out the "feel" of the two mice. It a preference thing.
Old 26-03-2011, 12:37 AM   #28 (permalink)
Dust in the Wind
Skud's Avatar
After a long time...
Guys how's Razer Cyclosa bundle and what's the price?
Gaming Rig:
HTPC Rig:
Skud is offline
Old 26-03-2011, 09:14 AM   #29 (permalink)
Wise Old Ghoul
Piyush's Avatar
its good and i think it is placed at 2k
--Get Backers
Piyush is offline
Old 26-03-2011, 02:19 PM   #30 (permalink)
Dust in the Wind
Skud's Avatar
That sounds good. Searching for some reviews...
PS. I think I will get Razer products at MD Computers.
Gaming Rig:
HTPC Rig:
Skud is offline
- by kool
- by ax3
