Old 06-03-2011, 05:46 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
sujeet2555's Avatar
Default smps problem
just encountered another nuisance.i have been noticed this symptoms from many days
my pc config is:
asus m3a78 em, amd 9650 x4.2gb ram,500gb seagate hd ,lg dvd writer and running win7.
i have a mercury cabinet+mercury 400w smps.my system is 1 yr old.i have attached hard disk and sata writer with sata power cable on 1 rail.no other component is attached with smps.then system runs fine.
i have noticed that when i attached fan or other peripherals to the same rail or other rail ,hard disk makes clicking sound while copying any files from dvd or writing dvds.either copying stops or i get burn error after clicking sound.i think either hard disk is not getting enough juice from smps.
what do you guys says about this situation.should i buy a new smps {suggest some value smps ,thinking of buying hd 5670 or hd5770 or repair the existing one {what should i tell to service center about the fault of smps}.
s.k.
sujeet2555 is offline   Reply With Quote
Old 06-03-2011, 06:44 PM   #2 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default Re: smps problem
Hard Disk clicking sound is not a good sign. First make a backup of your important things in your HDD. Check for any errors in windows check disk utility. Make sure that the socket is properly grounded.
For a PSU suggestion, you need to state your budget.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is online now   Reply With Quote
Old 06-03-2011, 07:52 PM   #3 (permalink)
sujeet2555's Avatar
i am high on that type of maintenance.that clicking sound don't occur when i just have hard disk and writer attached.no stopping on copying ,no write error
for psu budget ,just want sufficient value for money for gpu upgrade [only play at 1024 med/high setting ,because of crt monitor.on high res monitor starts to flicker].
never had buyed the pricey one.but may be 1k,i can spend on psu.
s.k.
Old 06-03-2011, 09:03 PM   #4 (permalink)
^^ open to buying online? if yes, get FSP Saga II 350W. & live peacefully for 5yrs.
Old 06-03-2011, 09:09 PM   #5 (permalink)
sujeet2555's Avatar
online yes , but only from trusted one.
i also like to add that to solve this problem i have given both hard disk and dvd writer to service center.they both come back as replacement.so both are new but still the problem remains ,so i think culprit may be the power.
s.k.
Old 07-03-2011, 12:39 AM   #6 (permalink)
i think you can find them at SMC international & ITWares (brought my FSP 400W from them).
total will be 200 more if you buy from ITwares as they charge for carrying charge. but SMC usually offers free shipping or charges low.
Old 07-03-2011, 11:36 AM   #7 (permalink)
Tensor
I would ask OP to try for Corsair CX400. He said he might get the 5670 or 5770.
But maybe I am getting paranoid or such.
However FSP is also good. Anyway to make OP's life easier, the links are below.
FSP Saga II 350W @1.55k
FSP Saga II 400W @1.85k
Corsair CX400 @2.8k
Originally Posted by Blizzard
...and the heavens shall tremble...
Diablofans
Force Strategy Gaming
YouTube
Xfire
Gaurav Bhattacharjee is offline   Reply With Quote
Old 07-03-2011, 02:08 PM   #8 (permalink)
sujeet2555's Avatar
psu replacement is the last option but please do stress on the problem solving first.
s.k.
Old 11-03-2011, 02:15 AM   #9 (permalink)
MegaMind's Avatar
The prob is the psu buddy...
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - 1TB 7200.12 - 9800GT - CM M600 - NZXT Gamma - XONAR DX + VS4121/XB500 - OptX AW2210
MegaMind is offline   Reply With Quote
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/137645-smps-problem.html
Thread smps problem | Digit Forum | BoardReader This thread Refback 20-07-2011 01:36 AM
- by kool
- by ax3
