Old 06-03-2011, 01:21 AM   #1 (permalink)
ithehappy's Avatar
Default Is my HDD corrupted?
For last few days I am noticing some lag in games like Fifa 10, NFS HP etc. But this issue was never existed before. So I was thinking it might be my Hard Disk which is done! Is there any way to check my HDD that it's running in max data rate or not?
Thanks in advance.
Mine is a Seagate 500GB @7200.
http://www.seagate.com/ww/v/index.js...00f5ee0a0aRCRD
i7 950SABERTOOTH8GB RAMGTX560690II +TX650
SGS II
ithehappy is offline   Reply With Quote
Old 06-03-2011, 06:12 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Is my HDD corrupted?
Download Seagate Seatools bootable version to check HDD for any bad sectors. It's a bootable CD image though version for windows is available I prefer the bootable seatools.
For checking your HDD for bad sectors and performance under windows use HDTune - it's the best app for checking and benching HDD
ToPsPeEeD = FaSt BuT StEaDy
Old 06-03-2011, 07:56 AM   #3 (permalink)
Try defragmenting and also do a virus check. You never know what malware came into your system!
Old 06-03-2011, 05:51 PM   #4 (permalink)
ithehappy's Avatar
Okay so I spent more than 2 hours to check the HDD and here are the results,
HD Tune Pro, Benchmark, File Benchmark and Error Test.
and also did the Error Checking under Windows of C, D and E drives,
Here this the Full Scan by NIS,
I am done with Defrag too. But is the Benchmark result okay? and is there any other problem in the HDD?
Thanks in advance.
SGS II
Old 06-03-2011, 07:34 PM   #5 (permalink)
sujeet2555's Avatar
scandisk,defragment,remove temp files,stop unwanted services and processes ,stop realtime scanning of antivirus.
s.k.
sujeet2555 is offline   Reply With Quote
Old 07-03-2011, 07:02 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
Thanks in advance.
from the HDTune error scan pic I can see one bad block/sector in your HDD - scan and fix it using seatools bootable version and also make sure your HDD is using Ultra DMA 5/6 mode under device manager.
- by kool
- by ax3
