Old 04-03-2011, 10:18 PM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Dell Studio 17 just shuts down! Need help!
I noticed that the temp for reached maximum 80 in normal use and the laptop just shuts down! have attached the screenshots from HW monitor.
I opened the laptop removed the dust still the same! i noticed that the thermal paste on proc was quite less!!! one more thing the fan that is near the proc heatsink is throwing air downwards instead of the back vent... i remember that hot air used 2 come out the back vent but now it dosent!
Is the issue with the fan? Can it be a RAM issue? will buying a laptop cooler help?
Please help.
Thanks in advance.
ankushkool is offline   Reply With Quote
Old 04-03-2011, 11:00 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Dell Studio 17 just shuts down! Need help!
Clean off the thermal paste using isopropyl alcohol (chemist) apply new.
asingh is online now   Reply With Quote
Old 04-03-2011, 11:04 PM   #3 (permalink)
ankushkool's Avatar
where will i get the thermal paste in delhi? any preferred brand? i think there maybe issue with the fan too...
Old 06-03-2011, 03:03 PM   #4 (permalink)
ankushkool's Avatar
anyone has an idea what sud be the normal temp?
- by kool
- by ax3
