Old 03-03-2011, 12:18 PM   #1 (permalink)
paroh's Avatar
Default suggest External , portable hard disk & pen drive
I thinking of buying the external, portable hard disk and pen drive.
But before buying any think i want to know more about them like the performance issue, and the type of power it needed like usb powered or need external power adapter in case of hard disk
As for hard disk i think 1TB is ok for me.
For pen drive 8-16Gb
External hard disk
Portable hard disk
Pen drive
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline   Reply With Quote
Old 03-03-2011, 12:29 PM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: suggest External , portable hard disk & pen drive
what's your budget for pen drive and HDD. there are high performance HDD/PD and mainstream HDD/PD.
desiibond is offline   Reply With Quote
Old 03-03-2011, 12:55 PM   #3 (permalink)
Mmmph!!!
doomgiver's Avatar
i dont think he wants a super-performance hdd.
external hdd=portable hdd (wait, am i missing something?)
doomgiver is offline   Reply With Quote
Old 03-03-2011, 05:04 PM   #4 (permalink)
paroh's Avatar
As i want normal USB 2.0 support hard disk, if possible can be upgrated to USB 3.0 for future use as i read that seagate freeagent can be used with usb2.0 and usb 3.0 by just replacing cable (Portable or external)
External hard disk or portable hard disk as if there is not much difference in the performance and price than i will prefer Portable drive over external drive.I limit the drive size to 1TB.
For pendrive the size i prefer will be between 8-16GB(USB 2.0 as i don't know pen drive with usb 3.0 is backward compatible with normal usb 2.0)
@doomgiver:external hdd=portable hdd there is some difference as far as i know portable hard disk takes power from usb cable itself but external hard disk need extra power adapter
Note:Must be Backward compatible to usb2.0 both in the case of external or portable hard disk and pen drive
Old 03-03-2011, 08:05 PM   #5 (permalink)
Mmmph!!!
doomgiver's Avatar
yes, all usb are backward compatible. thats how you can use usb 2.0 on a usb 1.1 port.
Old 03-03-2011, 08:24 PM   #6 (permalink)
Manchester United <3
Ishu Gupta's Avatar
The ones that need power are called Desk editions.
The USB3 versions of desk editions don't need external power.
And you want Seagate GoFlex Portable 1TB @ 5-5.5k
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 04-03-2011, 06:14 AM   #7 (permalink)
paroh's Avatar
So it supports both usb 3.0 and usb 2.0. Do i need to purchase usb 3.0 cable and 2.0 cable separately ?
Old 04-03-2011, 06:43 AM   #8 (permalink)
Living to Play
gameranand's Avatar
It supports both you don't have to buy another cable.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 04-03-2011, 07:45 AM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes. GoFlex comes with USB 2.0 adapter and for USB3.0 or eSATA, you need to purchase adapter.
Old 04-06-2011, 02:25 PM   #10 (permalink)
U can also check out BUFFALO Ministation 1TB.
Dave is offline   Reply With Quote
Old 04-06-2011, 04:05 PM   #11 (permalink)
saswat23's Avatar
Wink Re: suggest External , portable hard disk & pen drive
Buddy,
was it really necessary to dig out this thread after 3 months to make your 1st post in this forum.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 04-06-2011, 08:28 PM   #12 (permalink)
Stuck in Time...
Vyom's Avatar
^^ Haha.. not the kind of welcome he maybe expecting!
But not the kind of welcome, we too wanted to give him!
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
- by kool
- by ax3
