Old 03-03-2011, 10:15 AM   #1 (permalink)
Default Need advice to use DDR3 2000mhz RAM
I need advice to use DDR3 2000mhz RAM on gigabyte GA-785GMT-USB3
Motherboard guide says 1866+ OC Ram and not 2000+ OC
Will it be compatible?
Is someone already using this configuration?
As I need all the members advice before buying this RAM
Phenom II 955@4.2Ghz@1.35V |785G|coolermaster Hyper 212+|Mushkin blackline DDR3 4GB @7-8-6-18 1600Mhz |Coolermaster 600W Extreme| HD5770 @stock|Coolermaster HAF 922
waghanuroop1 is offline   Reply With Quote
Old 03-03-2011, 11:01 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Need advice to use DDR3 2000mhz RAM
yes. it doesn't support 2000MHz DDR3 but if you use 2000MHz module, it will be downclocked to 1666 or 1866. you better stick to 1666MHz modules for now.
desiibond is offline   Reply With Quote
Old 03-03-2011, 04:48 PM   #3 (permalink)
Thanks for ur reply.
So can I use 1866 Mhz memory or will it be also downclocked?
Please let me know
Old 04-03-2011, 06:56 AM   #4 (permalink)
Living to Play
gameranand's Avatar
I don't think 1866MHz RAM sells in market.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 05-03-2011, 10:13 AM   #5 (permalink)
Thanks...Please close this thread
- by kool
- by ax3
