Old 02-03-2011, 10:33 AM   #1 (permalink)
Default DDR RAM query
I have an old MSI K8MM-V mobo(Socket 754 AMD), I already have 1GB DDR RAM stick,
I need to use some additional amount of RAM,
SIS(System information software) says the maximum capacity of my mobo is 4GB, but the MSI site says 2GB,
So whats the actual capacity of my mobo?
According to MSI:-
Main Memory
• Supports DDR266/333/400 DDR DRAM for two 184-pin DDR DIMMs.
• Supports a maximum memory of 2GB.
According to SIS:-
Manufacturer 	MICRO-STAR INTERNATIONAL CO., LTD
Model 	MS-7142
Version 	1.00
Serial Number
North Bridge 	VIA K8M400 (VT8380) Revision 00
South Bridge 	VIA VT8237 Revision 00
CPU 	AMD Athlon(tm) 64 Processor 3000+
Cpu Socket 	Socket 754
System Slots 	3 PCI, 1 AGP
Memory Summary
Maximum Capacity 	4096 MBytes
Maximum Memory Module Size 	2048 MBytes
Memory Slots 	2
Error Correction 	None
And in CPU-Z it says DRAM frequency to be 200MHz, so is my RAM stick DDR400 or DDR200?
Xccentricity is offline   Reply With Quote
Old 02-03-2011, 11:17 AM   #2 (permalink)
Cool Buddy's Avatar
Default Re: DDR RAM query
doesn't really matter. 1 GB DDR modules cost Rs. 2000, wouldn't advise buying it, still if you do buy, don't waste money buying more than 1 GB
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 02-03-2011, 06:27 PM   #3 (permalink)
1GB is 1550+, I really need at least 1GB more of RAM,
And where can I find Arctic Silver 5 and Arctic Cooling MX2 in Bangalore, searched many electronics and computer shops in SP Road but no one has it.
(Even Cooler Master is not available, all the shops have some paste called "Nepali" one which is Rs.20!!).
Old 02-03-2011, 06:40 PM   #4 (permalink)
saswat23's Avatar
Instead of 2GB DDR RAM for 4k, go for a DDR-2 nVIDIA chipset mobo for 3k and 2gb DDR-2 for 1.5k.
0.5k more but the mobo will give very good quality graphics and ddr2 ram will perform even faster than ddr1 rams.
i5-2400 | P8H67M-EVO | DRW 24B3ST | WDC Blue 500GB | VENGEANCE 4GB DDR3 | FSP SAGA-II 500W | Zebronics Aviator | DELL IN2020M | MS Wired 500 Combo | Creative A-35 | iBall Rocky Headset
saswat23 is offline   Reply With Quote
Old 02-03-2011, 07:40 PM   #5 (permalink)
^^ good suggestion, but again finding a Nvidia chipset board for an ancient AMD proccy won't be easy.
@OP, for DDR1 look here: Pentium 4 3.0ghz with HT processor, 512mb 8500GT,1.5gb DDR1 rams. a member is selling it so you may get it cheap.
- by kool
- by ax3
