Old 01-03-2011, 05:23 PM   #1 (permalink)
sujeet2555's Avatar
Default realtek 5.1 problem
my pc config is:
asus m3a78 em, amd 9650 x4.2gb ram,500gb hd .5.1 audio system and running win7.
my pc was running fine untill i decided to clean it.i just switched it off,removed cover and blow out all the dust and closing it.while doing it i had unplugged all the cable from the back.after attaching all the cables and starting up.
my bios get reset to default by it's own.i just set the settings in bios as previous.after getting in to window.i checked all the connection .but while checking through realtek audio manager,i found out front speakers are not working.all the cables are connected ok.there is a unusual thing i noticed as
green one is front out,as i plug front audio cable in it ,it becomes center/subwoofer out.while yellow one also the same .i that's why i am getting no audio from front.cables are fine [check by plugging it into side speakers]
can anyone tell why realtek is showing this weird thing.
s.k.
sujeet2555 is offline   Reply With Quote
Old 02-03-2011, 04:09 PM   #2 (permalink)
d3p
"Official HD 7970 Owner"
d3p's Avatar
Default Re: realtek 5.1 problem
Connect everything back properly & map the audio outputs in Realtek Audio manger.
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
d3p is offline   Reply With Quote
Old 03-03-2011, 04:58 PM   #3 (permalink)
sujeet2555's Avatar
I have posted here after doing every type of troubleshooting as known to me.its simple isn't it,i connected rear audio cable to rear out [connection OK],center/sub cable to center/sub out [OK], but when i connect front audio cable to front out[green one],it shows center/sub in audio manager.when i play subwoofer i my sub+front right both plays.similarly when i play center my front left play.
likewise when i plug front audio cable into side speaker out and change my config to 7.1 in audio manager both speakers plays ok.but won't work in front out.
s.k.
Old 03-03-2011, 05:01 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Remove the Realtek chipset drivers. Restart. Install again, and restart.
asingh is online now   Reply With Quote
Old 06-03-2011, 01:17 AM   #5 (permalink)
sujeet2555's Avatar
thank you for all your replies,just fiddled some settings in bios and also reinstalled drivers.solved the problem by trial and error.
also i saved this profile in the bios and i tried to load previous profile but that didn't work.
once again thanx.
s.k.
Old 06-03-2011, 10:47 AM   #6 (permalink)
Super Moderator
asingh's Avatar
So it is working fine...?
Old 06-03-2011, 03:21 PM   #7 (permalink)
sujeet2555's Avatar
yeah its working.
s.k.
- by kool
- by ax3
