One of my friend has a celeron PC with 128mb RAM and 20gb HDD which he is not using. Its very old so, no one is intrested to buy it.
Now, the matter is that he has challanged me if i can damage the PC without actually affecting the H/W within minutes.
So, can anyone of you suggest how to do that???
Plz help me.
First things first correct your signature where it says 4TB ram. There's no such thing for memory sticks. What you mean is is 4GB. 4GB= 4096MB. FYI, Mb and MB are not the same .
@The Sorcerer i well know that. But you don't uderstand. Its my future rig.
@Ishu Gupta, as i said no one is intrested in it, its ver old. So, its better to experiment on it.
He means down the line sometime in future (lets say 20 years from now) , he'll have 4tb of ram. Now that can actually be possible. Who knows? But no way now.
@ saswat23
Buddy, why don't you try it as a secondary download rig?
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
@ vickybat
Moreover its not mine so cant really do anything. And talking about using it as a download rig, it wont work at all. My old pc with PentiumD, 256mb RAM n 80gb HDD slowed down tremendously when i opened 3tabs in firefox. And you think this crap can be used for downloading.
By the way why would he use it for downloading when he has a C2D PC, which consumes much less power than this.
But he is planning to experiment on this pc coz it doesnot even support USB-2 drives, restarts frequently, monitor turns pink automatically and after a lot of struggle works normally for sometime and again same problem.
Not worth upgrading too. So, better to experiment.
So, can you help me in this challenge..
---------- Post added at 11:58 PM ---------- Previous post was at 11:55 PM ----------
@ saswat23
@ saswat23
What personal satisfaction will you or your friend gain by "damaging" the PC?
If your friend does not want to use it, then please donate it for a noble cause.
let us all see the "i" in the "u".
Looks like its already damaged .
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
