Old 26-02-2011, 10:03 PM   #1 (permalink)
Tux Fan
shaunak's Avatar
Default A few question about IPS monitors
I spend a lot of time on my computer and my eyes frequently go dry after a while.
A friend told me that IPS monitors need less bright back-lights, hence are a lot easier on the eyes. Plus they have better color reproduction.
I am currently using a Samsung 19" TFT [Syncmaster 931]. I am looking to upgrade it to an IPS one.
3 quick questions:
- Is it true?
- How much would a 19"ish one cost me?
- How's Dell?
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline   Reply With Quote
Old 04-03-2011, 06:52 AM   #2 (permalink)
Living to Play
gameranand's Avatar
Default Re: A few question about IPS monitors
Originally Posted by shaunak
Is it true?
Yes. It is true.
Take a look at this
WIKI
About Tech Used
Why it is Preferred
All Panels comparision.
How's Dell?
Good.
These panels are quite difficult to find so you have to order them through shopkeeper. I think it would cost you around 20K.
In war, Victory. In peace, Vigilance. In death, Sacrifice.
Using TDF through mobile. Digit optimized this forum for mobiles. Works nicely YAY :D:D
gameranand is offline   Reply With Quote
Old 04-03-2011, 08:27 AM   #3 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes. IPS panels are much much better. Check Dell's ST2220T and U2211H. Do remember the high response time that IPS panels usually have.
desiibond is offline   Reply With Quote
Old 04-03-2011, 08:36 AM   #4 (permalink)
Living to Play
gameranand's Avatar
Prices???
Old 04-03-2011, 09:08 AM   #5 (permalink)
The Sorcerer's Avatar
Originally Posted by shaunak View Post
- Is it true?
Yup
Nope. Smallest you get is U2311H from Dell for 14k.
- How's Dell?
Does the job but always go by the model number, not the brand.
---------- Post added at 09:08 AM ---------- Previous post was at 09:06 AM ----------
Response time for IPS panels work different compared to TN panels. There's no issues on the ones that you're been getting for few years, but its only now you're seeing e-ips panels viz. cheapest of the all the IPS panel types.
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 04-03-2011, 09:18 AM   #6 (permalink)
Bond, Desi Bond!
desiibond's Avatar
U2211H should cost around 14k and ST2220T should cost lot more (no idea about the price). It's an IPS panel touch screen display.
- by kool
- by ax3
