Originally Posted by utkarsh009
now the dimensions(outer) are 15.5 x 8 x 15 inch. here is the attached photograph:
will this be sufficient for amd radeon hd 6850?
Off Topic.
Guys, one thing can be noticed now.
i.e Don't cover your Cabinet with cloth, just in order to protect it from dust.
Covering cpu is just like making CPU breath his own **** & moreover the inside temperature swing high, which is just bad for the lifetime of the Mobo & Proc.
Here the case may be, such kind of cabinet doesn't come with a top air fins, but still on the other side, you have your SMPS mounted on the back top & SMPS requires proper airflow in order to cool himself & cloth blocks that hot air to move out.
