I have recently got my hands on 10-12 old computer.I want to use it(dos programs,old games etc.)
I haven't yet opened it, but I tried starting it, & it was beeping continuously.
Can you guys tell me where can I get parts for such old computer and where in Mumbai?Even back panel ports are different so I would also need converters as well.
Thanks.
The truth is out there...anybody got the URL?
let us know what is the configuration ..
second hand part can available with the most of the companies who provide AMC
it will be difficult to get the the new parts or memory (even second hand memory is expensive ... my p4 is still looking out for 1gb SD RAM)
for converters walk into any stores on lamington road or even on road u will get it ..
beeping must due to few reasons ...
1) clean complete pc .. make it totally dust free .. use plenty of WD 40
2) check memory .. removing cleaning
3) if video card present . remove it clean it again put it in .
4) make sure there is motherboard is not touching to the chasis ..
watch on expenses dont spend more or u will feel atom was better choice later on
