Originally Posted by ra_sriniketan
I have a P-4 mac with 2.4GHz processor, 1 GB(333) DDR RAM, Nvidia Gforce FX5200 graphics card.But whenever I play a BR-Rip movie, after sometime it starts to hang.Is it normal for a machine with the above mentioned configuration?
Say you are using media player classic for watching those movies, then start the movie>pause it>open up task manager>give high or realtime priority to the media player.
Also disable your AV and other background application. Playing these movies required lots of processing power to decode the movie.
Cheers
