Old 20-02-2011, 01:15 AM   #1 (permalink)
Default Issue DVD RW Drive
I have Samsung DVD RW Drive SH-S222A model.
Now it only recognized DVDs, any CD/VCD media just fails to get loaded after inserting into the drive. Only karrrr karrrr sound and eventually no LED glows and silence thereafter. Tried at least 2 - 3 different CD/VCD and same result.
patkim is offline   Reply With Quote
Old 20-02-2011, 03:57 AM   #2 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Default Re: Issue DVD RW Drive
hah. looks like the lens is not able to read the discs. try lens cleaning media or take it to service centre.
desiibond is offline   Reply With Quote
Old 21-02-2011, 12:14 AM   #3 (permalink)
aswin1's Avatar
How old is it. Maybe you need to buy a new one.
aswin1 is offline   Reply With Quote
Old 21-02-2011, 11:34 AM   #4 (permalink)
Use a lens cleaner CD and it should be fixed.
Old 21-02-2011, 12:42 PM   #5 (permalink)
Democracy is a myth
rhitwick's Avatar
How old is the drive? If its more than 1.5yrs old, try cleaning the lens first, if it does not work change the drive or use it as only a DVD reader...
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now   Reply With Quote
Old 22-02-2011, 04:54 PM   #6 (permalink)
n.tech7's Avatar
Problem with DVD Writer lens I think
n.tech7 is offline   Reply With Quote
Old 22-02-2011, 07:22 PM   #7 (permalink)
CA50's Avatar
If its too old then its shopping time. Cleaning might help.
You can try opening the drive and drop 1-2 drops of oil on the rod on which the lens mechanism moves. generally with time the fiction between the rod and the lens mechanism increases which prevents the free movement to the lens and it fails to recognize disc
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
- by kool
- by ax3
