Old 18-02-2011, 03:27 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Mr.Awesome
nvrmndryo's Avatar
Unhappy Burning smell from my Logitech z-5500 when volume maxed out !?
hi , i bought Logitech z-5500 about 25 days ago , its rocks ! but whenever I turn volume to max , after 2,3 minutes smell like burning rubber comes from sub or center satellite , I m not sure ,, There is no decrease in performance , just whenever i max out its volume , smell starts to come ... i've read on blogs n many of having this problem ,, so any solution ? I mean I need to give them to service centre or its normal ?
nvrmndryo is online now   Reply With Quote
Old 19-02-2011, 09:20 PM   #2 (permalink)
Default Re: Burning smell from my Logitech z-5500 when volume maxed out !?
I think its either normal or manufacturing defect since you said many have it.
Contact manufacturers and ask. They should have a helpline.
Old 19-02-2011, 11:31 PM   #3 (permalink)
Mr.Awesome
nvrmndryo's Avatar
hmmm ,, i guess so ..
Old 20-02-2011, 06:25 AM   #4 (permalink)
Old 20-02-2011, 12:30 PM   #5 (permalink)
Mr.Awesome
nvrmndryo's Avatar
I contacted service center , n they said U have to bring ure speakers here ,, man whole speaker set is around 17 kg ,,,hw m i gonna get my speakers there ,,,
tht sucks ,,,,
Old 20-02-2011, 01:14 PM   #6 (permalink)
I think its better to take smell than take a 17 kg speaker far away + I think they will ask you to bring it there multiple times
Old 20-02-2011, 01:32 PM   #7 (permalink)
Adam young
sukesh1090's Avatar
btw why is that burning smell is coming?
:razz:| [AMD PhenomII 955BE 3.2GHz @ 1.25V] [CM Hyper 212EVO][Corsair carbide 400R] [Gigabyte GA 880GM-USB3] [MSI MD1GD5 R6670 @875MHz & 1150MHz] [4GB Vengeance 1600MHz] [Seasonic S12 II 520W] [LG W1943C 19"] [Seagate baracuda 1TB] [GM M6800] [LG DVD+RW]:razz:
My rifle and myself are the defenders of my country.
We are the masters of our enemy.
We are the saviors of my life.
-Rifleman's Creed
sukesh1090 is offline   Reply With Quote
Old 20-02-2011, 01:51 PM   #8 (permalink)
^ even manufacturers arent sure of that.
Old 20-02-2011, 11:25 PM   #9 (permalink)
Mr.Awesome
nvrmndryo's Avatar
i read sumwhere tht wen volume max out the voice coil heats n smell comes , but m nt sure whether its true ..
Old 21-02-2011, 10:23 AM   #10 (permalink)
Just make sure wires arent burning..
If smell gets too unbarable spray some room freshner
Old 21-02-2011, 12:16 PM   #11 (permalink)
Mr.Awesome
nvrmndryo's Avatar
lol ,,,its not about smell ,, i mean m scared if my speakers r damaged !!
Old 21-02-2011, 12:33 PM   #12 (permalink)
I think you should get it checked if service centre isnt too far.
Old 21-02-2011, 03:02 PM   #13 (permalink)
Mr.Awesome
nvrmndryo's Avatar
yeh , i will in one or two days ..
---------- Post added at 03:02 PM ---------- Previous post was at 03:00 PM ----------
another thing , I m not getting satisfaction on my onboard sound card ,, any suggestion about wich soundcard should i buy for Z-5500 ?
Old 21-02-2011, 03:23 PM   #14 (permalink)
Please specify budget.
Old 21-02-2011, 05:49 PM   #15 (permalink)
mayanksharma's Avatar
@nvrmndryo,
Go through these and revert back:
1. How often does it happen with the smell? I mean, does it only happens when the volume is maxxed? And even if it does...then for how long?
2. What are the volume levels of Center, Surround and Sub-woofer?
3. Try playing 0-100 Hz THX test with bass level maxxed and all the rest zeroed. Notice, if you can hear any popping sound from woofer? (excursion)
4. Do check the connections and fuse at the back of the woofer.
5. Make sure, the woofer side port isn't blocked and has sufficient space.
6. Do provide enough room for the amplifier's fins at the back of the woofer. make sure, the connecting wires aren't touching the fins at the back.
As for soundcard, Asus Xonar-DX is the best pick for Z-5500!
mayanksharma is offline   Reply With Quote
Old 21-02-2011, 06:34 PM   #16 (permalink)
Mr.Awesome
nvrmndryo's Avatar
@ techfreak : well my budjet is low i.e.1500/- rs ,, lol
but i can extend my budget ,,, first suggest me cards then i'll think about budget ,,,
i just need full performance by my system ,,so if there is no option but costly one ill wait 4 few months n buy ,, so we'll talk bout budget later ,,,,
---------- Post added at 06:34 PM ---------- Previous post was at 06:33 PM ----------
@ mayanksharma : wen my volume is maxxed then only smell comes ,, n my center , surround n subwoofer volume levels are full ...
il check another things n reply ..
Old 22-02-2011, 09:11 AM   #17 (permalink)
Asus Xonar DX- Rs. 3000 mrp
best I can think of..always gets mention in Digit mag's buyer section. Should serve all your needs.
Old 22-02-2011, 10:55 AM   #18 (permalink)
Mr.Awesome
nvrmndryo's Avatar
asus xonar dx problem is it "Doesn't Support DTS Surround Formats" ,
wt u say about this ?
Old 22-02-2011, 04:18 PM   #19 (permalink)
Get info here-
Asus' Xonar DX sound card - The Tech Report - Page 1
Old 24-02-2011, 06:25 PM   #20 (permalink)
Mr.Awesome
nvrmndryo's Avatar
gave speakers to service center yesterday , today i called them for status n they said tht they can't smell any burning smell,,, they've been playin system for 2,3 hrs ,,, so they said if anything happens like burns my system in future , they will provide service ,, so i guess ill bring my system back 2mrw !
LinkBack to this Thread: http://www.thinkdigit.com/forum/hardware-q/136994-burning-smell-my-logitech-z-5500-when-volume-maxed-out.html
Thread Burning smell from my Logitech z-5500 when volume maxed out !? | Digit Forum | BoardReader This thread Refback 15-06-2011 01:14 AM
- by kool
- by ax3
