14-02-2011, 11:02 AM
RAM query....
Hi guys, i am planning to get a 4GB ddr2 800Mhz RAM stick from singapore. Brand will be G-skill or A-data.
Now i am using 2x2GB kingston 800mhz, 1x2GB nanya 800mhz ram sticks...
will i have any prob if i install the 4GB RAM stick???
14-02-2011, 11:18 AM
Re: RAM query....
no problem provided your mobo has 4 slots. but you can get g.skill, adata from here too. ask for a mushkin or patriot if you want from outside
14-02-2011, 01:20 PM
Re: RAM query....
my mobo is DG43GT, it supports upto 16GB RAM....
One of my friend told never use different brand sticks at the same time....
I didnt ask him y....
R u sure i can use diff RAM...
Will there be dual channel problem???
14-02-2011, 02:46 PM
Super Moderator
Re: RAM query....
Idealists suggest this, if someone is going to OC then it helps. RAM should be same density and speed to keep the channel architecture.
14-02-2011, 03:04 PM
Manchester United <3
Re: RAM query....
Yep, different RAM modules "can" cause trouble sometimes. Random BSODs etc.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
14-02-2011, 04:02 PM
Re: RAM query....
oh... if i use 2 kingston and 2 nanya? I there still a problem...? not going to overclock....
14-02-2011, 04:30 PM
Fullbring
Re: RAM query....
u can use both brands as far as the frequency/clock timings of RAM modules r same.
14-02-2011, 06:50 PM
Re: RAM query....
but ishu and asingh isnt it that all others will get clocked down to speed and settings of lowest ram. correct me if i wrong.
14-02-2011, 07:26 PM
Super Moderator
Re: RAM query....
He is getting both rated at 800Mhz speed. So there would not be lowest gets dominance.
Though if I am not incorrect the total population of the DIMMS would be:
DIMM 0: 2GB Kingston
DIMM 1: 2GB Kingston
DIMM 2: 2GB Nanya
DIMM 3: 4GB New Company
This way you will loose the dual channel architecture cause all DIMMs are not of equal density.
14-02-2011, 08:13 PM
Re: RAM query....
Originally Posted by asingh
^^This way you will loose the dual channel architecture cause all DIMMs are not of equal density.
Equal density meaning that all should be 2GB or 2*2GB & 2*4GB???
14-02-2011, 08:17 PM
Re: RAM query....
ok got that asingh thanks.
14-02-2011, 08:18 PM
Re: RAM query....
@mailme.manju, yes. the ram sticks should be in even number & should be of equal capacity irrespective of clockspeed.
14-02-2011, 08:39 PM
Re: RAM query....
So i can have RAMs of this order without any problems right 2*2GB & 2*4GB? Provided 2*2GB as kingston & 2*4GB G-skill.... Is this ok?
16-02-2011, 06:38 AM
Fast 'N' Furious
Re: RAM query....
DIMM 2: 2GB Nanya
He won't loose dual channel even if he don't has same density ram sticks .
Well, it depends on chipset.
OPs mobo has G43 chipset which supports Flex Memory Technology so he can use memory modules with different size/capacity and still remain in dual channel mode.
I think he should bring Crucial Ballistix
Reason: Automerged Doublepost
16-02-2011, 09:17 AM
Super Moderator
Re: RAM query....
17-02-2011, 03:59 AM
Fast 'N' Furious
Re: RAM query....
^^ No both channel will run in Dual Channel Mode.
OPS mobo has 2 blue Ram slot ( Channel A ) and 2 Black Slot ( Channel B )
For for eg. If he populates Channel A ( two Blue slots ) with 2X Kingston 2GB modules he would get dual channel in Channel A
Now if OP populates Channel B ( two black slots ) with one Nanya 2GB module and another 4GB module he will still get dual channel mode in channel B but the mobo will use only 4 [ 2+ (4-2 ) ] GB ram as dual channel instead of consuming all 6 GB present in channel B.
24-02-2011, 01:50 AM
Re: RAM query....
Thanks for your suggestions... So shall i get a 4GB RAM ? Or sell off the nanya 2GB RAM and buy 2*2GB kingston as of the RAM i am currently using? Or stick with 6GB for a while...Purpose 100% for gaming...
24-02-2011, 05:47 AM
Fast 'N' Furious
Re: RAM query....
I would suggest you sell off your nanya 2GB module and get 2*2GB ram modules - with that you would get 8GB mem - all running in dual channel - 8GB is more than enough for gaming.
24-02-2011, 08:35 AM
#19 (permalink)
Re: RAM query....
:-P:-P
