Old 12-02-2011, 08:39 PM   #1 (permalink)
pulkitpopli2004's Avatar
Default PC - boot up prob
hello frndz
i dont what has happened to my new Rig.. jst after 5-6 days it come up with a prob in which it does boot in one go..
i need to press power on button 4-5 times,,, or sometimes more than that too..
whenever i press on led blinks present on cabinet and jst after a second it goes off..
kindly help me on this
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
pulkitpopli2004 is online now   Reply With Quote
Old 16-02-2011, 12:39 AM   #2 (permalink)
Default Re: PC - boot up prob
anyone/..???
Old 16-02-2011, 07:02 PM   #3 (permalink)
looks like PSU problem. but not so sure.
Old 16-02-2011, 10:30 PM   #4 (permalink)
XLr8
arpanmukherjee1's Avatar
maybe faulty mobo??
check each part separately for errors on a running system
arpanmukherjee1 is offline   Reply With Quote
Old 16-02-2011, 11:19 PM   #5 (permalink)
Stuck in Time...
Vyom's Avatar
I had faced this problem where I work. The LED's blinked for two seconds, and then system turns off.
And that was a PSU problem!
Can you hear any beep sounds? Can you enter BIOS, or it turns off, before even giving a chance to enter that?
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 17-02-2011, 09:15 PM   #6 (permalink)
yes 2 LED blink for a second,fan rotates and the system turns off,could not enter BIOS even..
yeah i hear some sound dont knw whether that was from mobo or PSU... sound was very less actually..
Originally Posted by arpanmukherjee1 View Post
maybe faulty mobo??
how to check each part on running system?
@sam - after few tries it sometime CPU works too.. i dnt knw whether it pSU,mobo or something else..
Last edited by pulkitpopli2004; 17-02-2011 at 09:15 PM. Reason: Automerged Doublepost
Old 18-02-2011, 11:17 AM   #7 (permalink)
Cool Buddy's Avatar
Since it's not been many days, I suggest you immediately contact the shop you bought it from. If you got it assembled in a shop, they should replace any faulty parts within the first week
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 18-02-2011, 03:09 PM   #8 (permalink)
yes i have assembled that at home only..
now i asked for support from where i have purchased my PSU..
is the PSU faulty or mobo??
Old 18-02-2011, 08:24 PM   #9 (permalink)
Stuck in Time...
Vyom's Avatar
The most probable defective piece seems to be PSU.
But still, we can be wrong. You will have to take the suppliers word for it
Or you can ask a friend for help and hope he lends you his PSU to check
- by kool
- by ax3
