Old 07-02-2011, 04:39 PM   #1 (permalink)
d3p
"Official HD 7970 Owner"
d3p's Avatar
Default Buying Advice & SMPS Query
My friend has this following conf
Intel i7 950 @ 4.2, H70 Water Cooling, UD3, 3x2GB DDR3, 4 TB [4x1TB], GTX 295, CM Silent Pro 600w.
Someway he sold his GTX 295 in order to get a GTX 570.
Now my query is, IS THIS SMPS will Work Fine ???
I have used this SMPS Wattage Calculator
Newegg.com - Recommended Power Supply Calculator.
As the specs says GTX 570 requires a 500w min & i hope his 600w doesn't requires any upgradations.
I can't trust CM600w, thats why I doubt ?
Guys any comment on this ??????
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
d3p is offline   Reply With Quote
Old 07-02-2011, 06:34 PM   #2 (permalink)
Default Re: Buying Advice & SMPS Query
wats the 12v ampere ratings on the psu????
aloodum is offline   Reply With Quote
Old 07-02-2011, 08:24 PM   #3 (permalink)
should work without any problem. CM PSU aren't of same quality & build of some of its competitors but will handle easily.
Old 08-02-2011, 02:28 PM   #4 (permalink)
d3p
d3p's Avatar
" 40A on a single +12V rail ".
IRC Krow
Old 10-02-2011, 06:53 AM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
It will work just fine.
ToPsPeEeD = FaSt BuT StEaDy
Old 11-02-2011, 07:49 AM   #6 (permalink)
Jaskanwar Singh's Avatar
Silent pros are good AFAIK. Will work.
- by kool
- by ax3
