Due to DATABASE ERROR i cannot continue with my old thread regarding ram. So i have to open a new one. Anyhow pls clear my doubts regarding RAM.
I have ASUS MBM4A78T-E with Transcend 2GB(1333) ram,Windows vista 32 bit.
I thought of upgrading the RAM to 4GB(1333) with Corsair product as specified in the QVL of motherboard.
But at the end it is written: "When installing total memory of 4GB capacity or more, Windows 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended."
1) does it mean that for my case upgradation is useless and i should be happy with what i have now?
Next: if upgradation is not supported then i want to use corsair product(for its performance) instead of transcend. For that which one is better to use:
2)Single module 2pcs OR kit of 2. is it all the same?
3) can a single module be used from a kit of 2 or it works as a pair?
