I have seen many adds where same video is splitted over a number of screens to give a large screen appearance what is this techonology. how can i use it for my day to day presentation works
1) Get multiple monitors. (Preferably same size and resolution)
2) Get a decent Video card that supports the number of monitors you want.
3) Connect them and Voila. Few twaks and it'll behave the way you want.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Yes it is possible. You need a system with a disrete video accelerator card (GPU) and a motherboard which supports the same. Most do these days. Two connectivity cables are put into the GPU and lead to 2x individual monitors. In theory your desktop is now spread across two panels. BUT applications (not games) will open on an individual screen. So if you have MS-Word open on the left screen it will never show on both halves. But you can drag it where ever. Takes a while to get used to, but is good if you want to do editing, quality check, reference work. I declined multiple monitors at my office -- but that is my say. Setting it up is not that difficult.
If you are interested let us know your budget and current configuration. You want a whole new setup or a best possible upgrade.
Best.
And for ur query u have to use a graphic card (from ATI/Nvidia).
The more the no of monitors the more the eye-candy
ATI supports this multi monitor setup known as Eyefinnity....
so can a Laptop screen and PC monitor work together GPU is GTX460?
I'd explain it to you, but your brain would explode... Trust me :hot:
i5 760, Asus P7P55D-EVO, Zotac GTX 460, VX550, Win7 64bit,4GB RAM @1600MHz, WD 500GB Caviar Black
