01-02-2011, 10:47 PM
Bazinga!!!!!
smps making weird sound
im using an 250 w smps that came along with my iball i7272 cabinet;
recently the smps is making weird sound,its coming from the fan.
i tried cleaning it,bt it still makes noise.the only way to stop it is by giving a slap on the back of the smps.
is there any way to get rid of this noise.or is it time for me to change my power supply
01-02-2011, 11:15 PM
Manchester United <3
Re: smps making weird sound
Loose fan?
iBall SMPSs suck anyway.
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
01-02-2011, 11:34 PM
Don Draper is coming back
Hehe. same as my SMPS (2 years ago).
Its a problem in fan's bearing, i guess.
I am MaxPayne. My Wife and Daughter were murdered.
02-02-2011, 12:56 AM
XLr8
open fan. take machine oil or warm grease and put few drops into the gap of blade and support
02-02-2011, 01:12 AM
The fan will be inside the PSU.
Not recommended to open the PSU.
02-02-2011, 02:36 AM
not that tough. if you talking about any hazard, just avoid touching the aluminium fins & the transformers. the fan can be cleaned & oiled easily (done with old PSU many times).
02-02-2011, 09:34 AM
XLr8
true if PSU in warranty. othervise very easy to open and if properly earthed, no way u can get a shock
03-02-2011, 09:49 PM
Bazinga!!!!!
here is wht hapened
i tuk my iball smps to their service centr,the smps came with 3 year warranty,bt the warranty seal was not found,so they rejected it.i took it to the shop where i bought it from,where they askd 2 day tim to fix it.
i have gt another psu zebronics 400w,which is working tottaly fine in my other system,
i connected my zebronics smps to the system,i turned on the ups,a green led turned on the surface of the mobo,bt when i pushed the power button the cpu, it didnt turnd on????
im really confussed,the same zebronics smps is working fine in my one systm,bt not working in other?my mother board id intel dg43nb;can any one tell wht the problem may be,does connecting the zebronic smps instead of iball caused sm damage?
03-02-2011, 11:43 PM
XLr8
^^ if all connections r correct then it must work.
attach a snapshot of the mobo with connections. that would give an idea of what u say.
11-02-2011, 09:55 PM
Bazinga!!!!!
never buy iball smps,they are the worst.
whenever buyin smps check for the warranty seal.
eventhough iball smps came with 3 yrs warranty,some of the iball smps wont have the warranty seal or sticker making your warranty void.
11-02-2011, 10:31 PM
What's your system configuration?
14-02-2011, 06:40 PM
Bazinga!!!!!
intel core 2 quad 2.66,intel dg43nb mobo,4 gb ddr2,500gb x 2 ,nvidia 9500 gt & a dvd rw.
my cabinet is iball i7272.
15-02-2011, 07:56 AM
XLr8
is ur problem solved now?
