Old 31-01-2011, 11:23 PM   #1 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Default DVI- HDMI help, DVI-VGA issues.
I have HD 4890, which came with a DVI-HDMI adapter, but sadly, it is not working. Can some one please forward me to a store which sells this adapter?
And I have another query. I am now using DVI-VGA converter connecting rig to my HDTV. But the problem is, the maximum resolution I am able to get is 1600x1200. While my TV is a Full HD thing. Is this a issue with the DVI-VGA adapter I am using?
thanks.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is offline   Reply With Quote
Old 31-01-2011, 11:49 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: DVI- HDMI help, DVI-VGA issues.
You tried the adapter on another set up. Also when using DVI-VGA are you making the relevant changes in CCC - HDTV section.
Ebay has the adapter you desire. Example.
asingh is offline   Reply With Quote
Old 01-02-2011, 12:23 AM   #3 (permalink)
The thing is, CCC is not even recognizing it as a HDTV. It is just detecting it as a CRT monitor. Same was with my previous display Viewsonic VG1930WM. But luckily, it's optimum resolution was listed in the available resolutions. Can you be specific about the settings i have to adjust,bro?
And,I am searching for an adapter rather than a whole wire. Because, Getting a HDMI cable at 300RS range is not good. Considering the amount of time it has to work. I have a good quality HDMI cable with me, all that i need is a converter which supports audio signals. I have found couple of adapters on ebay.in but none of them are audio compliant.
Old 01-02-2011, 01:08 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Under Desktop and displays right click on the monitor option at the bottom. And then choose configure. From there choose HDTV Support and check the resolution you want for your panel tv.
I think this one supports audio.
Old 01-02-2011, 02:03 AM   #5 (permalink)
Tried that already.. still shows a maximum resolution of 1600x1200. And I don't know what is causing the HDTV to get detected as a Generic non PnP monitor!?
I tried updating drivers, downloading some other 32" Monitor drivers and applying it. Still, nothing happened. Tried a different cable, different DVI-VGA converter.. nothing worked.
Old 01-02-2011, 02:05 AM   #6 (permalink)
Super Moderator
asingh's Avatar
Then get an DVI-HDMI adapter. Best bet.
Old 01-02-2011, 02:09 AM   #7 (permalink)
^ yea.. I should. Will order it tomorrow. No bank balance right now
Thanks for listening
Old 01-02-2011, 07:56 AM   #8 (permalink)
Cool Buddy's Avatar
DVI-VGA connector doesn't support a resolution higher than that (1600x1200). I had read this recently but am unable to find the link now. Either use a direct DVI connection if the TV has one or use a DVI HDMI adapter.
and there is nothing wrong with Rs. 300 cables. They are all the same, just boasting about gold plating and platinum coating to increase the price, doesn't make any difference in the real world scenario
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 01-02-2011, 08:30 AM   #9 (permalink)
Super Moderator
asingh's Avatar
They can support higher. 2560.
Old 01-02-2011, 06:10 PM   #10 (permalink)
Cool Buddy's Avatar
Oh yeah, a bit of confusion. 1600x1200 is the max resolution if you are using a single link cable. Probably that is the cause of the problem, but it is unlikely coz single link cables are not so common
Nokia 5230 :(
Old 01-02-2011, 06:23 PM   #11 (permalink)
I used the same cable with Nvidia Geforce 9400gt, it had no problems detecting the monitor and changing the resolution to 1920x1080 by itself. The only change was, i wasn't using any converters back then as 9400gt itself had a VGA port.
- by kool
- by ax3
