Old 29-01-2011, 03:27 PM   #1 (permalink)
sona's Avatar
Default Best place to buy PC in New Delhi
can anyone tell me which would be the best place to buy an assembled PC in new delhi.....???
adn
sona is offline   Reply With Quote
Old 29-01-2011, 05:34 PM   #2 (permalink)
XLr8
arpanmukherjee1's Avatar
Default Re: Best place to buy PC in New Delhi
nehru place. SMC intenational & cost to cost computers
arpanmukherjee1 is offline   Reply With Quote
Old 29-01-2011, 08:19 PM   #3 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
go for smc (smcinternational.in), cost to cost (costtocost.in) or computer empire(102 meghdoot building ).smc and costtocost are little overpriced as compare to computer empire.
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline   Reply With Quote
Old 30-01-2011, 12:30 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Depends. You can also order parts online and get good deals. And avoid the guck of Nehru Place.
asingh is offline   Reply With Quote
Old 31-01-2011, 10:46 PM   #5 (permalink)
Try SMC International and Computer Empire only. Cost 2 Cost is bad, they try to hand over old stuff trying to clear up the old stock, and they usually dont have the stuff you require.
But the Best is Computer Empire.
KunalAggarwal is offline   Reply With Quote
- by kool
- by ax3
