Old 28-01-2011, 09:33 PM   #1 (permalink)
Bazinga!!!!!
sanoob.tv's Avatar
Exclamation no signal on monitor
i was installin windows 7 on my freinds machine,it asked for some drivers in order to continue installation,i went to get my mobo cd,when i returned it was all gone,(blank screen)
i restarted the system,and the monitor displayed "no signal",
in the cpu all the fans are spinning,can hear the sound from hdd and al,but no output
i tried many things,resetting bios by cmos jumper and bios battery,changing rams,etc
the one thing i noticed was,usually the led on the cabinent is blue and red(busy)
bt now its only red
any help on this?
sanoob.tv is offline   Reply With Quote
Old 28-01-2011, 09:42 PM   #2 (permalink)
Manchester United <3
Ishu Gupta's Avatar
Default Re: no signal on monitor
Sounds obvious but did you check the monitor cable?
Do you have a graphic card?
i5 2500k 4.4GHz @ 1.25v | CM Hyper 212 Evo | HD 3000 @ 1.5GHz | Asus P8Z68-V Gen 3
2x4GB DDR3 1600MHz CL9 | 160GB 7200rpm + 160GB 5400rpm | W7 x64
CM690 II USB3 | Corsair TX750W V2 | APC 1.1KVa | Dell U2312HM + Sansui V8 19"
Razer DA Black + Razer Goliathus | XBox360 wired x2
Senns HD201 | PSP Slim 8GB MSPD | N5800XM 8GB MSD | Speedtest
Ishu Gupta is offline   Reply With Quote
Old 28-01-2011, 10:24 PM   #3 (permalink)
Bazinga!!!!!
sanoob.tv's Avatar
i checked the cable,it works fine,n i dnt have a graphics card
Old 29-01-2011, 12:16 AM   #4 (permalink)
Super Moderator
asingh's Avatar
Try to reinstall the OS.
asingh is offline   Reply With Quote
Old 29-01-2011, 12:34 AM   #5 (permalink)
How old is the motherboard?
Usually no-display issue is attributed to a problem either with the motherboard or processor or memory (RAM).
Perhaps i am wrong, thus, kindly await the expertise of other renowned members.
let us all see the "i" in the "u".
insaneYLN is offline   Reply With Quote
Old 29-01-2011, 11:50 AM   #6 (permalink)
Properly check connections on the back of CPU
Old 29-01-2011, 05:33 PM   #7 (permalink)
XLr8
arpanmukherjee1's Avatar
these r also related to HDD.
remove HDD and see if bios screen shows up.
arpanmukherjee1 is offline   Reply With Quote
Old 29-01-2011, 06:57 PM   #8 (permalink)
refit you ram properly,hdd cable
Old 30-01-2011, 01:50 AM   #9 (permalink)
is the OS legit? i doubt. or were you trying to install from other DVD?
if nothing works, install XP & than upgrade to Win7.
Old 30-01-2011, 09:10 AM   #10 (permalink)
Bazinga!!!!!
sanoob.tv's Avatar
well i tried all that bt no use
im assuming the problem is with the mobo
today when i turned on the cpu,it worked fine at first,bt suddenly after some time the system turned off again(not shutdown);and now its having the same problem "no signal" on the monitor
is it a virus?or some mobo problems?
Old 30-01-2011, 10:51 AM   #11 (permalink)
I think motherboard and overheating problem.
Old 30-01-2011, 02:31 PM   #12 (permalink)
XLr8
^^ possible. clean cabinet and cpu+chipset fins with vaccume
Old 30-01-2011, 07:44 PM   #13 (permalink)
mkgupta64's Avatar
Even Im facing the same problem since quite some time.
Not even able to enter into BIOS.
checked everything except my RAM & CMOS Battery. Cud it be related to either of these two? Is der anyway by which i can check my RAM & battery while it is still installed ? I dnt hv access to other PC which support my DDR 1GB RAM.
mkgupta64 is offline   Reply With Quote
Old 30-01-2011, 08:39 PM   #14 (permalink)
Bazinga!!!!!
sanoob.tv's Avatar
Originally Posted by thetechfreak;1327549 begin_of_the_skype_highlighting**************13275 49******end_of_the_skype_highlighting
i hope its the heating problem,
k,i tried to turn on the system before two hours bt it didnt seemed to work,
the power is k,fans spinning,dvd rw working(open and close),
bt the problem is it didnt even show bios screen,nothing comes on the monitor except the"no signal";and only the busy led(red light) on the cabinet is glowing....
Old 30-01-2011, 08:59 PM   #15 (permalink)
XLr8
is ur hdd still connected ?
if yes. disconnect it and reboot
Old 31-01-2011, 02:24 PM   #16 (permalink)
d3p
"Official HD 7970 Owner"
d3p's Avatar
Try this.
1. Get a new Thermal Compound or Thermal Paste.
2. Remove the Processor & clean the surface of the Heat Sink & processor.
3. Apply Thermal Paste on the Processor & hook up the fan.
4. Check the connections on the MB & if booting properly then go to the BIOS.
5. Check whether the HDD is detected or not.
6. If everything is fine then it the time to change your Power Supply [SMPS].
Check & let us know.
Sapphire HD 7970 Unboxing
i7 2600k|Ma IV Ex-Z|Venomous X RT - CM R4's Push Pull|16GB RipjawX|Sapphire HD7970 OC, PhysX - Palit SP GTX570|OCZ Vertex 3 120GB|WD Black Raid 0, 40GB[Lisa]|AX850w|Asus Xonar DX, VK278Q|HAF 932|NZXT Sentry II| Logitech G27 Racing Wheel, G15, Attack II-HandBrake, HD C310|Razer DA|Bose Over Ear HP|Powershot HX40IS||E7-00|
IRC Krow
d3p is offline   Reply With Quote
Old 03-02-2011, 09:45 PM   #17 (permalink)
mkgupta64's Avatar
I hv tried Booting without connecting Hard disk also bt the same pblm, motherboard light is ON, CPU front facing indication Green alws on, Red keeps blinking.
Even tried restoring my BIOS, by loading it to a pen drive n then tried booting.. but again, nothing happened.
Any help guys ??
Old 03-02-2011, 11:20 PM   #18 (permalink)
monitor cable trouble maybe.properly connect pins.
Use different monitor.
Old 03-02-2011, 11:50 PM   #19 (permalink)
XLr8
go back to basics.
remove everything. only mobo+CPU + GPU only if no IGP
the mobo speaker should generate 4-5 beeps at regular interval
if this happens then put in single ram.
if bios shows up let sytem on for 1-2 min
then put in hdd
if os loads put in GPU.
i do this in case when i dont know which component is causing prob.
Old 06-02-2011, 02:07 PM   #20 (permalink)
mkgupta64's Avatar
Tried the Basics also..
Connected only Mobo + Processor n tried booting. Mobo green light is ON but no sound from internal speaker..
Does it mean, Mobo is out of service??
Anyway, its Intel 865 GBF + P4, a quite old config and no support avl on net either.
Help me guys.
Old 06-02-2011, 06:39 PM   #21 (permalink)
d3p
d3p's Avatar
Try resetting from the CMOS, I hope it will do the job.
IRC Krow
Old 06-02-2011, 06:58 PM   #22 (permalink)
mohityadavx's Avatar
Thumbs up Re: no signal on monitor
try changing the motherboard's bios cell i had same problem few months back and it worked
mohityadavx is offline   Reply With Quote
- by kool
- by ax3
