Old 26-01-2011, 01:55 PM   #1 (permalink)
G!ZMo FReeK
Default 4GB RAM showing only 2.75
i Have Just bought a new System, {check my siggy}.
i Have installed Win 7.
i Have 4gb RAM but its only showing 2.75 GB dont know y ??
Can anybody PlS. gimme solution & my PC is also SLOW, not that much fast as it should be with the kind of proccy i have.
PlS. gimme a solution
-=[DDS]=- is offline   Reply With Quote
Old 26-01-2011, 03:12 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: 4GB RAM showing only 2.75
You would need a 64BIT OS variant.
asingh is offline   Reply With Quote
Old 26-01-2011, 04:20 PM   #3 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
how much ram you have shared for graphics (IGP), check the dedicated graphics memory and let us know
@asingh even 32 bit will show 3.25 G.B not 2.75 G.B.
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline   Reply With Quote
Old 26-01-2011, 04:34 PM   #4 (permalink)
The Assassin
Cybertonic's Avatar
^^ Nope. If using a 32 bit OS with an IGP using 512 MB Graphics memory it will show 2.75 GB.
Nothing is true. Everything is permitted.
Steam : $/@$]-[ DK
http://steamcommunity.com/profiles/76561198047340352
Cybertonic is offline   Reply With Quote
Old 26-01-2011, 05:08 PM   #5 (permalink)
put a entry level graphics card.. You should get 3.25 GB RAM..
Old 26-01-2011, 05:38 PM   #6 (permalink)
why is it not like this: 3.25Gb for ram + 512Mb as shared graphics memory?
Old 26-01-2011, 06:51 PM   #7 (permalink)
CG Artist++
well i have a dual boot win 7 x64 and win 7 x86 in my x86 (shared 512 M.Bfor IGP ) it still showing me 3.25 G.B ram.
@ Op reset your bios setting to default and then check .
Old 26-01-2011, 10:51 PM   #8 (permalink)
G!ZMo FReeK
0k so is there anyway to change that default memory of iGP
AMD PHENOM X6 @ 2.8GHz||GA-880-UD2H||KINGSTON 4GBDDR3 1333MHz UNGANGED ||SONY DVD WRITER 24x||TAG SAPPHIRE wth 4D SMPS || 500GB WDC GREEN||
Old 26-01-2011, 11:28 PM   #9 (permalink)
Bond, Desi Bond!
desiibond's Avatar
yes. you can change in in BIOS. just refer your mobo manual. And I don't think 2.75GB of RAM is causing slowness. What exactly do you mean by slowness?
desiibond is offline   Reply With Quote
Old 26-01-2011, 11:32 PM   #10 (permalink)
G!ZMo FReeK
Like apps opening slowly & taking time.
& sometimes getting struck for few secs.
i Dint expected all this things to happen
Old 26-01-2011, 11:40 PM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
If it's fresh OS, I don't think it is due to RAM. Are you using authentic version of windows? Because a fresh install of win7 runs very well on my laptop that is powered by a core2duo T7300 and 2GB of DDR2 RAM. and the experience index shows 4.1.
1. Find updates for drivers.
2. Looks for a rogue processes eating up resources
3. update ATI catalyst suite.
Old 27-01-2011, 12:10 AM   #12 (permalink)
G!ZMo FReeK
iTs a Fresh Update.
& i Also feel that its due to poor performance of OS, its a Cracked copy.
i Need a good one.
Old 27-01-2011, 06:46 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
Not every mobos bios is equally made - some mobos ( even without built in IGP ) with discrete gfx crad will show you only 2.75GB of ram as usable and some other may show you 3.25GB on cosumer grade 32 bit OS.
Some mobo bios has a option called memory hole remapping ( or something like that ) and if you enable it you may get get 3.25GB as usable.
Only way to use 4GB and more Ram properly is to use a 64 bit OS.
@ OP - Just get win 7 home premium x64 bit edition - it's cheaper than ultimate version and comes with most of the important features.
ToPsPeEeD = FaSt BuT StEaDy
Old 27-01-2011, 08:57 AM   #14 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Totally agree with topgear. Atleast get Win7 HP OEM version costs less than 4k if I am right. Only problem being that you cannot upgrade this to next version and you can't transfer it to a new PC. If I am right, MS is not selling x86 and x64 as different copies. You pay for Home Premium and you get both x86 and x64 OS install DVDs.
Old 28-01-2011, 12:26 PM   #15 (permalink)
G!ZMo FReeK
Can anyone PlS. tell me difference between 64-bit & 32-bit ???
i Know that in 32-bit the data bus is of 32-bit & in 64-bit the data bus is of 64-bit, so which supports m0re data then 32-bit & is much faster.
Any other difference ??
i'VE heard from people that 64-bit has lots disadvantages ass it doesnt have proper application support ??
Many apps doesnt run on 64-bit, is this true ????
Old 28-01-2011, 03:06 PM   #16 (permalink)
his true ????
win 7 64 bit support all 32 bit application , only problem is IF u have old hardware which might lack driver 64 bit driver
32vs64
http://windows.microsoft.com/en-IN/w...sked-questions
http://support.microsoft.com/kb/294418
Rajesh345 is offline   Reply With Quote
- by kool
- by ax3
