Old 25-01-2011, 06:44 PM   #1 (permalink)
mohityadavx's Avatar
Cool Sony ps2 hdmi
Hi!
I am having a PS2 slim one. Is there any way by which I could run it on my TFT panel. Plz don't suggest very expensive method as my budget is tight.
mohityadavx is offline   Reply With Quote
Old 25-01-2011, 07:25 PM   #2 (permalink)
I am the night! I am....
vickybat's Avatar
Default Re: Sony ps2 hdmi
^^ I have a ps2 slim too. It doesn't have any hdmi or dvi connectivity so no way it can run on a tft monitor. But if you have an lcd tv, you can use the audio video composite cables. But the quality will detiorate in an hd compliant panel and wont look as good as in a crt tv.
Ps2 was designed to run standard definition content i.e 640x480 (480p).
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline   Reply With Quote
Old 26-01-2011, 10:16 AM   #3 (permalink)
yeah,even I think there is no way to do it
Old 06-02-2011, 01:44 PM   #4 (permalink)
official's Avatar
Location: A small town near Siliguri, West Bengal in Darjeeling district
First of all u can connect ur ps2 to any lcd or tft using an external TV Tuner cards..doing this u can play the games in MONITORS..but the video wont be good coz it will be downscaled..u can directly connect them to lcd tv through AV cables those are provided along with the consoles similarly u wont achieve any visual glory coz it will be downscaled again..better play it in crt tv or SD tv for which they are made.
Core i5 750, MSI p55m gd45, 2x2gb corsair, Dell s2409w 24'', ATI HD5770 1GB DDR5, CM690, windows 7 ultimate 64x, PS3 80GB Console.
PSN Id- subhasis13
official is offline   Reply With Quote
- by kool
- by ax3
